hi
i installed svcd2dvd 1.5 today
before i convert the bin/cue files to vobs i can read the bin/cue files with daemon tools and it mounts the image but once svcd2dvd has done its work they are corupted , i have proven that it is svcd2dvd by making an exact copy of the bin/cue files before i started encoding the second film and before i started i mounted all bin files 1 at a time with daemon tools , once i had finished creating the vob files the bin/cue files couldnt be mounted with daemon tools but the copys of the bin/cues i had made could be
can someone explain why this happens
I was suprised at this post as SVCD2DVD justs ripps the BINs and doesn't change them in any way. I also did a test. I did a byte by byte comparison with WINHEX before & after SVCD2DVD had processed a BIN. There were no differences.
Can you do a file comparison at byte level with a hex editor to back up your claim?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
yes ok i will do that but what i did do was -
before the first time i ran svcd i had mounted both images (bin & cue) into daemon tool .i then converted the bin/cues into nobs and burnt the dvd and then i wanted to burn a couple of cds of the bin/cues but nither daemon tools or nero would except them.
so i then tried another set of bin/cues but this time i copied them to a temp folder first , tested them all with daemon tools and they all mounted fine and i could view the svcd films fine .
i then ran svcd2dvd on 1 set of bin/cues and created audio_ts/video_ts folders and vobs
the bin/cues that i had let svcd2dvd proccess were no longer valid but the copied ones (in the temp folder) were just fine .
you must admit it sounds like svcd2dvd is somehow corrupting the bin/cues
this is the error i get of daemon tools
well ive tried a hex editor and compared files and it says there is no differences , so why is one set (the untouched ones) fine but the ones that svcd2dvd used no good
ChrissyBoy could you recreate what ive done
1 make a temp folder and copy 1 set of bin & cue files into it
2 mount all bins/cues with daemon tools , to prove they work ok and unmount all
3 use svcd2dvd to convert 1 set to vobs
4 now try to mount the bin/cue files again
see if you get same result as me -
Well without doing your test i can think of one possibility to explain the issue. SVCD2DVD renames files to replace - with _. It may have done so in your case and so the reference in the cue file will no longer be valid. Open it in notepad and also reneame the bin filename.
yes it could.
Is SVCD2DVD the program for my HD files?
By rimam in forum SVCD2DVD & VOB2MPGReplies: 19Last Post: 20th Mar 2008, 15:12 -
SVCD2DVD problem with TS files
By rickfaldo in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 26th Dec 2007, 12:14 -
Trsf of M-DV from Cam to 'Puter Stops - Fixing Corupt AVI File?
By GlenM in forum Capturing and VCRReplies: 0Last Post: 18th Dec 2007, 21:49 -
DVDs corupt near end of movie
By NBninja8 in forum Authoring (DVD)Replies: 11Last Post: 23rd Jun 2007, 05:10 -
Multiple HDTV TS files to DVD with SVCD2DVD HELP
By ndoggac in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 18th Jun 2007, 13:21
