Hello, I am not sure where to go for help with something like this, and I figured that maybe this would be a good place to start. I use a program called ISO Buster to extract MPG Files out of BIN Files. Until recently I have had no problems doing this. But today I tried to extract a BIN and it gave me an error stating:
Sector 450 Couldn't Be Read
Error 05/64/01
Ignore Retry or Quit.
I tried a few other ISO extraction programs such as WinISO and UltraISO. These programs extract the ISOs without any errors like I listed above. But when I try to play the MPG file in Windows Media Player 9, it does nothing. I tried to play it in PowerDVD and it loads and I hear sound, but the picture is all wacked out. I can see a little bit of video at the top of the screen, but the rest of the screen is blocked out with green distortion and blockiness. I have tried to extract a few different BIN Files and they all yield the same green results. Any help anyone can offer is greatly appreciated.
Thank you for your time.
Easy one. I have been through this before. First off vcdgear is better to extract the bin...make sure the fix MPEG errors is checked. If it does not work for you then get yourself alcohol120% and it will definitely do the job...it has a special function for reading vcd's and bins w/ errors.
Hope this helps.
If you have any more questions about this just reply. -
Thanks for the suggestion, i will try that out later tonight. I find it odd tho that the last 3 bin files i have tried have all given me the same results. i'll try it out and let you know.
Thanks again
MAKING SRT FILE FROM IDX and SUB after EXTRACTION FROM A DVD USING AVIDEMUX
By montejohn in forum SubtitleReplies: 1Last Post: 4th Mar 2012, 16:47 -
Question re "lossless" extraction of clips for later DVD authoring
By TURB0x in forum Authoring (DVD)Replies: 4Last Post: 9th Jun 2010, 04:08 -
MKV chapter file extraction problems
By ikarishinji41 in forum EditingReplies: 1Last Post: 22nd Mar 2010, 11:03 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
extraction of image frames from MJPEG file
By vivian in forum Video ConversionReplies: 2Last Post: 3rd Oct 2007, 04:21
