I am quite new at this and was wondering if anyone here as an easy way (guide) on how encode my dvds for backup using the CCE method. I've read quite a bit on it but I can't find an all-in-one guide from start to finish. There just seems to be SO much work involved. I currently transcode my DVDs but I notice that there are quite a few artifacts in some movies and that can get annoying. I've read that by using the CCE method I can do SEVERAL passes of the movie(s) which, in the long run, will result in better video quality. Thanks for your guys help. I really appreciate it!![]()
have not been around in a while, but when I do encoding of DVD's I use DVD DECRYPTER - DVD2DVDR - SUB RIP - plus - SCENARIST to author and sometimes IFO-EDIT.
Thanks alot,
dreadogg -
I appreciate the response but what exactly is scenarist? Is this a method using CCE? Thanks again.
Newbie, advise for easy 1 step backup of dvds
By mbogda in forum Newbie / General discussionsReplies: 5Last Post: 4th Sep 2008, 13:18 -
CCE guide for PAL to NTSC conversion
By alexs_eu in forum Video ConversionReplies: 9Last Post: 21st Jun 2008, 07:41 -
How To Batch Author Compliant DVDS - The Easy Way
By Dilemma in forum User guidesReplies: 12Last Post: 2nd Jan 2008, 03:28 -
VDubMod & logoaway-Easy Guide-but 22hrs to process????????
By thegeeman in forum Newbie / General discussionsReplies: 2Last Post: 17th Aug 2007, 09:20 -
authoring DVDs guide
By aldaco12 in forum Authoring (DVD)Replies: 6Last Post: 18th May 2007, 07:56
