I have sucessfully made 2 coasters after ripping a Divx file to dvd and then authoring it with tmpg. It goes to burn it and it write to the cd for maybe 2 seconds and gives me this error.
I am using memorex dvd-r's.
Any ideas?
By "ripping a Divx file to dvd" do you mean encoding it to an mpeg file?I have sucessfully made 2 coasters after ripping a Divx file to dvd and then authoring it with tmpg. It goes to burn it and it write to the cd for maybe 2 seconds and gives me this error.
If so, does it play on your PC?
Also, are you using the proper media for your DVD burner? -
Correct, I ripped it to mpeg and yes it does play on my pc.
As far as media goes... i have a dual drive, it can record - and + -
That's a media problem. Usually lowering the burn speed will help, but since Sonic's burning app (TMPG DVD Writer) doesn't support this, you'll either have to use higher quality media, or a different burning application.
I ran into the same issue with my LiteOn LDW 411 drive, and Verbatim Datalife 4x DVD+R. I upgraded the firmware on my LiteOn from FS0F to FS0H and that fixed the problem.
Try installing the latest firmware for your burner.
-Chakra.
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 17:46 -
error while burning DVD DL using tempgenc dvd author
By rgpai9972 in forum Authoring (DVD)Replies: 2Last Post: 2nd Jun 2009, 22:15 -
tmpg dvd author - pal ntsc setting?
By jin007 in forum Authoring (DVD)Replies: 4Last Post: 19th Aug 2008, 15:39 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 19:59
