I burned it on a Memorex CR-RW with nero. I played it on a dvp_s530d dvd player. This site said it should play cd-rw. What should i do?
What did the player say about the disk ???
Not bothered by small problems...
Spend a night alone with a mosquito -
Hello!
This site does not say it play SVCD's. It does not so sorry your Sony player only plays VCD's. Read about your player here:
https://www.videohelp.com/dvdplayers.php?DVDnameid=433&Search=Search&#comments
I would definetly recommend you to buy a new player your player does not even play MP3's.
If you would like to watch your movie on your player you need to convert it to VCD a format with less resolution so I would not recommend it most VHS tapes look better. But if you like to convert your SVCD file to VCD for burning here is the guide on how to do it:
https://www.videohelp.com/guides.php?formatconversionselect=SVCD+to+VCD&search=Search+Sincerely Joakim Agren!
Help needed with BD Burning, PC can play burned BD but TV cant!
By Shirokii in forum Authoring (Blu-ray)Replies: 8Last Post: 17th Nov 2011, 15:15 -
Help - Y wont my burned movie play
By sweetcheeks82 in forum DVD RippingReplies: 4Last Post: 18th Aug 2011, 13:37 -
Can't play burned DVDs - In need of some serious help!!
By fustrated in forum DVD & Blu-ray PlayersReplies: 13Last Post: 7th Jun 2008, 11:18 -
Burned DVDs only play on my computer
By kissy in forum Newbie / General discussionsReplies: 16Last Post: 7th Jan 2008, 12:48 -
want to play burned cd in my car
By terrie29 in forum Newbie / General discussionsReplies: 2Last Post: 20th Oct 2007, 01:55
