I decided to throw my sony dvdr. because nero is not compatible with it.sux.
so i wanna noe what dvdrw which has the same writing capablitiy, and also can use nero and cheap.
the stats are: dvd+rw 4x, dvd+r 4x, DVD-RW 2x, DVD-R 4x, DVD-rom 12x, cd-rw 16x, cd-r 24x and cd-rom 32x.
if can recomand better and cheaper is better.
btw,i live in singapore. if those living in singapore can tell me the price is also good.
pls and thank you in advance.
budget is below 300.
pls help.
thanx
I have a SONT DRU500A. I haven't thrown it away, although I can understand your frustration.
I very recently bought a new Liteon 811S.
I have not burnt many disks yet, but I succesfully burnt some "garbage" low cost media my SONY was unable to burn (and some even recognize as DVDRs!!!).
I spent $150 for the drive. It records +R at 8x and +RW at 4x. -R have the usual max. speeds.
What has been the best "extra" feature is 40x recording on CDRs and 24x on CDRWs. My previous burner did 24x only on CDRs and I thought that was enough. 40x is even better.
Highly reccomended...The more I learn, the more I come to realize how little it is I know. -
Liteon, NEC, Pioneer. All excellent drives... I suspect that Liteon and NEC will be the cheapest for you.
And if you don't want the Sony, send it to me. I'll even pay shipping!
- Gurm
keyboard help urgent
By dnmnbg in forum ComputerReplies: 2Last Post: 3rd Apr 2012, 22:45 -
AVStoDvd Help, urgent
By DaneClark in forum Authoring (DVD)Replies: 1Last Post: 21st Oct 2010, 21:22 -
Urgent help needed pls. converting mp4 to xvid- cant get sound
By prendersparty in forum ffmpegX general discussionReplies: 4Last Post: 14th Sep 2010, 14:35 -
Software help, URGENT
By ianbeddow in forum EditingReplies: 4Last Post: 6th Aug 2010, 05:23 -
messenger urgent help!
By alintatoc in forum ComputerReplies: 2Last Post: 1st Jun 2009, 10:39
