Results 1 to 9 of 9
  1. okay, i bought some fuji dvd+r's from an ebay auction. i know they are usually made in japan. but these discs (it didn't come with a label on the spindle) has a silver color top and it says made in taiwan. then when i checked it in dvdinfo, it said it was RICOHJPNR00. it also said the speed was 2.4x i need some clarafication here please
    Jun 2001
    Richmond , VA
    Whats the problem ? Most brand name discs ( Fuji , Memorex , Verbatim , ect. ) are not manufactured by the company on the label . They contract other manufacturers to do it for them . Just check the media list .
    Keep it on the big cam !
    Nov 2003
    West Texas
    Clarification? Fuji buys disks from various sources, Taiyo Yuden in Japan and Ricoh/Ritek in Taiwan---and there may be others. Look in the DVDMedia section over on the left and look up Fuji to see the different types of disks that users have found. The Ricoh 2.4x +R's have a pretty good rep, so I doubt you'll have problems with them.
    Sep 2003
    USA, MN
    Those are the exact same disks I bought at best buy the day after thanksgiving for $1 per disk. Although, dvdinfo reports them as 2.4X speed, if you have a lite-on burner you can burn them at 4X without any problem.
  5. well, the confusion was that i thought fuji's are made in japan. and plus, i read here that if it's made from taiwan it's usually not good. i just thought i might have gotten a fake or some bad media since i thought that all fuji's are made in japan
    Jun 2001
    Richmond , VA
    No , not all Fuji discs are made in japan . Also , just because its from Taiwan does not mean its a low quality disc . Some very good brands come from Taiwan such as Ritek and Ricoh .
  7. The only Fuji's I've seen Made in Japan (TY) are the 10-packs in jewel cases of DVD-R. Even the 10-packs of +R are Made in Tawain. All spindles +R or -R are Made Tawain.
    Sep 2003
    USA, MN
    The dvd media code that you listed (RICOHJPNR00) is richo manufactured and is of very good quality. I've burned about 75 of these and never had any problems, except with 3 of them that skip and jitted at the last 5 or 10 min of the movie, which could be in part to burning them at 4X speed. Either way that's a pretty good ratio.
  9. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    right Fuji from japan = TY, from Tawain = Ricoh. I dont think I've seen reports of Fuji using anything other then those two for +R, which is why I took bestbuy up on its 4x 100 pack the other day.
    Sadly I think that Fuji -Rs are to much of a gamble for me personally so I stay away from them.
