I've searched for a how to but can't find anything. This may be a dumb question, but what software do you use to capture minidv from a camcorder using a firewire cable?
You should have some software with your camcorder. Just check the disks that should have been with the cam.
Hey,
I borrowed a friend's MiniDV camera. I noticed it has a usb port. Does anyone know how to capture the video through the usb? Can i use VDub? -
Without any further detail I would say no. USB2 is for streaming and images. For Video transfer you have only 1 option - firewire.
Well then could i play the video in the camera and straem it into the computer as if it was live?
The answer is: no (check your manual). Or maybe, try it, if you have too much spare time. Why not? And try to approach your cam at an angle so it can't see you...
MiniDV capture too dark!
By johnb41 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 22Last Post: 7th Feb 2010, 13:21 -
Fast-forward MiniDV during capture?
By occams_r in forum Capturing and VCRReplies: 3Last Post: 27th Dec 2009, 16:37 -
MiniDv Capture Advice
By afoote@acslink.net.a in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 13th Nov 2008, 07:22 -
Which Codec should I capture in for MiniDV over Firewire
By AussieHusky in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 30th Oct 2007, 22:33 -
HELP- MiniDV capture TOO DARK
By cheeverm in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 27th Jun 2007, 14:03
