I got a bit adventurous and tried to join 3 DVDs (after extracting them with DVDBackup) and back them up using DVD2OneX 1.2 (I didn't realise this version has a join feature). Anyway the file is too big too burn. I left the output at 4472 but when I try to burn it says the DVD is 4.9 GB after joining them selecting 4472??? Is there anything I've done wrong? How do I make the file smaller so I can back it up? Should I import that 4.9 GB file into DVD2OneX?
use 4444
4472 is too big for most dvdr brands -
Three DVDs is a bit much to ask DVD2OneX to do. At a certain point the software can no longer make compromises in quality for the amount of data you're trying to cram in there. It should have even given you a warning screen that says the total original size is more than double the final projected size.
Another thing you can try is to take the 4.9gb VIDEO_TS folder from your first try and then crunch that. Just be warned that you're going very deep into Blocky Image City. -
OK
The 3rd DVD was only half an hour so I thought it might be OK. But the second attempt at 4444 again produced a 4.9GB file. I'll try and do one now with just the two DVDs which I imagine will be fine.
Cheers for all your help and Happy New Year!!! -
PS
What shall I call the new file when I burn it in toast. I usually choose the name of the disc but obviously now there's two??? -
names are for id purposes only.
you can name it
MY_CREATION_DVD
or
LOOK_WHAT_I_CAN_DO_DVD
its up to you!
How can I join two sided dvds.......................?
By forest.lawn in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2011, 18:51 -
Ripbot Not Producing Locked File Size
By Rustsatz in forum Video ConversionReplies: 0Last Post: 15th Jan 2010, 09:40 -
Producing DVDs from HDV footage
By lasereyes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Mar 2009, 17:25 -
Too big size after join two DVDs
By ByteVV in forum Authoring (DVD)Replies: 8Last Post: 25th Sep 2007, 04:46 -
Cannot join two DVDs
By vertical in forum Newbie / General discussionsReplies: 9Last Post: 7th Sep 2007, 00:23
