I have a film in avi that the audio is fine when is played in media player but when i convert to mpeg the audio is fine in the beginning but at long the film goes more the sound came early.
sorry for my english but anyone can help me?
Results 1 to 18 of 18
Load the video into Virtual Dub, and note how long the video runs. Then load it into Gold Wave, and note how long the audio runs. If the audio ends to soon, you can select Effect-->Time Warp... to make the audo in synch with video when you save it and mux it with the original video.
Hello. -
i try what you tell me but noe the audio is sync in the end but is not sync in the beggining
What do i do? -
Originally Posted by FrankieDuxHello.
Hi,
Ive also been having this 'gradual sync gain' problem. I have recently converted an AVI file to a MPEG using virtualdub to split the vide and audio and then encoded it with TMPGenc. When the video starts it is out of sync, then after about 4mins30secs of playing it is in sync and stays in sync throughout the rest of the video.
Tommyknocker I have found the information you said you needed to know.
In Virtual dub it says that its legnth is 0:25:33.635
I GoldWave it says that its legnth is 0:25:33.257
Therefore the difference is 0.378 seconds
Any help you can give is highly appreciated
Thanks a lot
Savior118 -
This is in addition to my last post:
I forgot to include that until the audio and video is in sync (until about 4mins30secs into the video) The audio is before the video - so I can hear people say something before I see tham say it.
Thanks again
Savior118 -
My File is:
Video: 1.46.27.93
I see the video information in virtual dub.
And then i extract the audio in goldwave and it tell me that is:
Audio: 1.46.23.568.
I try to put in goldwave the same time that the video and for diferent times i try some other lenght but when it become right in the end is not sync in the beggining and if is sync in the beggining at long the film go it become the sound early.
Can you Help me? -
it gives a error wint virtual dub freeze
"Virtual dub has carshed due to a program error" -
wiht virtual dub mod tell me this:
2063 frames masked (14 frames bad, 2049 frames good but undecodable)
What can i do?
Tks -
One of two things:
Save the file under a new file name, the new file should not have the questionable frames.
Or click here.Hello. -
i see the guide Fixing bad frames without losing any audio.
but i can find any note about the bad frames.
I my doing something wrong? -
Did you find the bad frames log on your C: drive?
Hello. -
Of course. It is how you know what frames on your video are bad, so you can edit them out.
Hello. -
Thank you Tommyknocker.
I check for errors in virtual dub mod and then i save the file as a new avi and in the end the audio is perfectly sync.
one more time Thank you.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
