Well I just made 2 coasters last nite using Nero 6. Backup 3 movies but wasted two DVD+Rs. All disks came from the same batch (same box of 5 actually). 1st time I had this prob with these memorex disks (RICOHJPNR01), I've used over 50 of them so far with no prob's and last nite was the 1st time I made coasters using Nero with these Memorex disks. Could I have screwup some Nero setting so the prog dont finalize the disks? I was using Nero earlier to backup some DVD data disks so could it be some settings was set up wrong. Funny is that after a reboot Nero burned OK, but fails on a second burn, but after another reboot, everything works fine again, so far. Just starting to have this prob with Nero 6 since last upgrade. Is there some bug or prob with the newest nero 6. Used a Plex 708 burner. Sorry for post if this a known prob...just dont want to make any more coasters if this is a known Nero 6 prob, hate to have to switch to another burning sw since I been using Nero for a long time.
Or is it a firmware issue.
upgraded Plex 708 to firmware 1.04....could this be the prob?
Every things works fine when using CloneDVD to burn.
I used Nero Vision Express (latest upgrade) to fix up some home video and then burned them on to a DVD +R using NEC ND2500. The disc works fine on my computers DVD-Rom drive but if I try to play it on my other DVD player (Philips 728) nothing happens
I then made a copy to my hard-drive and used CloneDVD to burn it to disc and it works fine (on both players).
Anyone know if there is a problem with Nero 6? -
That sounds very similar to a problem I had.
I burned a new DVD using NeroVision Express and it is not readable in 3 different DVD players (Panasonic SC-HT75; Panasonic DMR-E50; Grundig GDV 100D0). The menu displays and functions fine, but I can't play the title. It does play fine on the computer. Further, Nero Recode 2 will not read the files and gives me the following message:
"Nero Recode 2 encountered an error and cannot continue.
Encoding error - illegal program state occured".
and then hangs.
Here is what I did:
I used Nero Recode 2 to take a title from a DVD and create a Nero Digital title. (I had to do this because every other tool only lets me read the first 10 seconds of each VOB file).
I then imported that title into NeroVision Express and edited it, added chapters and menus and burned a disk in my Pioneer DVR-S606 recorder.
I have now burnt three disks with different settings and none of them are readable in the devices listed above. I believe the problem must be with the encoding by NeroVsion Express because of the error message I got from Nero Recode 2.
I raised a tech support problem to Ahead on Jan 11 and they still haven't bothered to get back to me.
Like you did with CloneDVD, I user Nero Burning ROM to copy the discs and they work fine. However, I can't copy the discs I burnt with Burning ROM. Go figure.
I think there are major problems with Nero 6! I'm now sorry I did the honest thing and paid for a copy. Their tech support is appalling.
How to Upgrade firmware of Samsung MM-DG25?
By GetmeColors in forum DVD & Blu-ray PlayersReplies: 6Last Post: 2nd Feb 2011, 15:25 -
GoVideo DVR4100 Firmware Upgrade
By csupan in forum Newbie / General discussionsReplies: 2Last Post: 17th Aug 2009, 22:03 -
Samsung BD-P1500 firmware upgrade
By D-Generate in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Mar 2009, 07:50 -
PHILIPS DVP642... how do I upgrade the firmware?
By mummer43 in forum DVD & Blu-ray PlayersReplies: 39Last Post: 14th Jan 2009, 19:45 -
How to do firmware upgrade for a DVD Player
By Tiger_Lion in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2007, 01:33
