Easy way of converting .AVI with AC3 sound to DVD-Mpeg WITH the AC3 sound.
Hi all, i just saw the topic about how to do this, i wrote this guide a while ago, thougt i share it with ya'll. I dont mean to offend the other guide-writer or anything, this is just how I do it...
Greetz and much0s rezpect0s!
GUIDE:
I just wrote this guide for people who want to make GOOD dvd's out of .avi files, with dolby
5.1 sound, and because i couldn't find an easy guide on how to do this.
This guide is maybe not fastest way to do this, but i've done it alot of times allready, and i
NEVER EVER got a dvd that resulted in audio/video out of sync or anything else...
Actually... it took me some time to realize how simple this actually is...
So here's the deal:
Tools required:
Virtualdub
BeSweet
Tmpgenc (-Plus)
Step 1 - Audio Part
--- I always do the audio part first ---
Open up Virtualdub and select the .avi file u want to use.
(note: if u have 2 .avi parts first join them using this guide:
http://www.polarhome.com:793/~afonic/join.htm )
Under file select: save .wav and rename the saved file to extension .ac3
(note: give it a name u can remember, because we have to convert this file later on to create a
proper one, without the wav header vdub puts in.)
When u got the original .ac3 from your avi, load up BeSweet:
*1 - Select the .ac3 file under input
- Select where u want to save the NEW PROPER.ac3 file
(Note: Name the new file Proper.Ac3.Audio or something...)
*2 Make sure BeSweet is set to ac3 conversion, leave all other settings intact.
(like in the pic.)
*3 Hit AC3 To AC3, leave it running, approx 8 mins.
Well u now have a PROPER ac3 stream. (to multiplex with the video later on.)
Step 2 - Video Part
Ok, back to Virtualdub again, open it up and select your avi file.
Then select under audio: no audio
Under Video: direct stream copy
Then file-> save as .avi
(note: name the new avi file NO.AUDIO.avi or anything)
--- so far: u created a new (usefull) .ac3 file and a .avi file with no sound? GOOD!---
Step 3 - Converting the NO.AUDIO.AVI to .m2v.
First of all make sure what type of .avi u have NTSC/PAL
(with avicodec for instance)
Note: If u want to add subtitles, i suggest to use direct vobsub, it will auto-load when
converting the video if you name your .srt/.sub or any known format to the same name as your
video. For more info: https://www.videohelp.com/edit#20
Ok, now start up Tmpgenc (plus).
1. Just use the wizard, select NTSC/PAL, hit next.
2. In the next screen, open your NO.AUDIO.AVI as video source.
DON'T SELECT AN AUDIO FILE!!! Just leave it blank, hit next.
3. Select Other Settings (1) and under advanced set to Full Screen (keep aspect
ratio) (2)
Hit next.
4. Since u can only put about 4199,43 data on a dvd, set it to approx 95 % of disc capacity, to
make sure that when u mux the audio, the resulting file doesn't get to big for your dvdr-disc.
5. On the last page select, output video and audio as individual streams.
Hit OK. and wait until conversion finishes.
--- So far, u now got an ac.3 and a .m2v file ---
Note: U can delete the .mp2 file, cause it contains NO.AUDIO... remember
Now u can choose to go on and auther a dvd with the to elementary files, with dvdlab for
instance or u can multiplex 'em together for use with tmpgenc dvd author or something.
Optional: Step 4 - Multiplexing .ac3 + .m2v
Open up Tmpgenc again,close the wizard and select file-> mpgtools-> simple multiplex
Select your AC3 and your M2V file and hit run!
Couple of mins later u'll have an complete .mpg file, with (dolby 5.1) ac3 sound.
Succes!
If u have any comments or questions, just ask me!
Greetz, ElayZ
ELOY Z.-
thank you for your guide but:
re-encoding ac3 (which is a highly compressed audio stream with lossy compression) to ac3 again results in rather poor sound quality -- at least not as good as what it should be...
better to just fix the stream - guides found on this site ....
also besweet is known for producing not quite to spec (or legal) ac3 streams .... great program otherwise ... can't beat the price non the less ..
your guide also doesnt really get into the fact that your method may produce out of sync audio ... or the source may or may not be 24fps or 29.97 fps or 25fps or what size is the source files (frame size) or the use of a bitrate calculator and the use of VBR (instead of the shown CBR) ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
why reencode the ac3?? have you tried just to fix the ac3? or do you get audio sync problems then??
https://www.videohelp.com/forum/userguides/186739.php -
Yeah, i tried fixing the stream, that didn't work, so i tried this and with me it works super, i don't get poor quality audio, and it runs great in sync, if i try to use that ac3 fix thingie, that works absolutly crap, even with the GUI... it just doesnt work...
The avi's i use are just "normal" xvids/divxs in 23,blabla fps or 25 fps -
Just wondering if any of you have tried a little program I have been using for some time now with super results and very very very easy to use it works with ac3 files of any amount of channels or for sure up to 5.1 anyway. It is called VSO Divx to DVD. I have made many dvds using xvid or divx source files with great success. I have even gone as far as putting one whole season of tv episodes onto one dvd however I would not suggest it as the resulting quality has deminished alot. Give it a try once what could it hurt. Also another plus is it only takes aprox. 45 min at most to encode whole movie directly to video_ts folder then use nero to burn as dvd!!
Later Gforce598
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 22:53 -
easy, free avi to dvd program
By ir0n_ma1den in forum Authoring (DVD)Replies: 2Last Post: 30th Jul 2009, 18:52 -
Convert AVI with H264 and AC3 to AVI with XVid and AC3
By ashwin.terminator in forum Video ConversionReplies: 4Last Post: 26th Jul 2009, 12:17 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
converting mpeg2/ac3 and avi/ac3 to avi/lambmp3
By corumz in forum Video ConversionReplies: 2Last Post: 17th Sep 2007, 10:32
