I've been backing up DVDs for some time now (using DVDDecrypter, IfoEdit, DVD Shrink, etc.). I've been removing some menu items with IfoEdit and I want to also remove their corresponding menu buttons. I've been trying to use the free version of MenuEdit, but to no avail. I was just wondering if paying the $16.50 for the registered version of MenuEdit is really worth it? I've been trying to find posts by other users regarding this topic, but I couldn't find any that helped. Thanks!!
I've been using Menuedit for some time now and it is worth it. That said, If I didn't own it now I would buy DVD Stripper which automates what you're doing now with DVD Decrypter and Ifoedit and makes it much easier and faster. The makers (of DVD Stripper) are finalizing a menu editing program which they are going to give to the registered owners of DVD Stripper which will do the same things as Menuedit. The price of DVD Stripper is a little over $20 if I remember correctly and more than worth it. It saves lots of time and work to get the exact results you want.
Is upscaling really worth it?
By bobbysafety in forum DVB / IPTVReplies: 20Last Post: 10th Dec 2010, 11:04 -
What do you think this pc is worth....
By lordhutt in forum ComputerReplies: 3Last Post: 3rd Nov 2010, 07:00 -
dvdfab worth the $40?
By glockjs in forum DVD RippingReplies: 30Last Post: 25th Jan 2008, 05:28 -
Removing/Hiding Buttons - Menuedit
By _impromptu_ in forum Authoring (DVD)Replies: 6Last Post: 8th Nov 2007, 19:33 -
Is the Matrox RT.X2 worth it?
By shockaholic in forum EditingReplies: 1Last Post: 22nd Jul 2007, 14:31
