Hi,
A month ago I bought I bought a PHILIPS DVDRW416 writer to create my own DVD's. But till now without any luck. I can create DVD but they won't playback on my PHILIP DVD763SA. I used DVDXCOPY and CLONEDVD after ripping a dvd with Smartripper. The discs I used are of the brand PHILIPS. According to the specifications of PHILIPS the 763SA must be compatible with +R/+RW standard. That's why I bought their writer. Can anybody tell me what I'm doing wrong? Or what program, settings etc. I must use to ensure compatibility?
The strange thing is that -r disc will play on the player. This is also according the specifications. I find this a strange situation, because PHILIPS supports +r/+rw standard and no -r/-rw standard!
Regards
Maurice Bessems
Results 1 to 1 of 1
Philips DVDR3576H/37 - Burned Discs Won't Play in Xbox, PC DVD Drive
By jbd5010 in forum Capturing and VCRReplies: 18Last Post: 20th Mar 2011, 04:11 -
Problems with Philips +R DL discs
By carlmart in forum MediaReplies: 17Last Post: 29th Sep 2010, 08:24 -
Philips DVP642 having trouble with X16 discs
By CaspianCanuck in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Aug 2007, 09:49 -
Philips DVP5960/37 Won't Read Discs
By synchro505 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Aug 2007, 02:57 -
Philips 20X SPD2413BD won't read 8cm DVD-R discs
By nlec in forum DVD & Blu-ray WritersReplies: 1Last Post: 5th Jun 2007, 12:03
