looked around the How To section on this site, but didn't have much luck. the help for Nero doesn't walk you thru the steps. is there a guide somewhere on this site or can someone, who's done it before with Nero, provide a brief step-by-step? thanks.
Hello, check my guide:
www.geocities.com/omegaweaponvcd/vcd_guide.htm
You need Nero Vision Express 2, it comes with the Nero 6 ultra edition pack.
Good Luck. -
actually, do u know if it's possible for Nero to display chapter titles in the menu in other languages? when i was adding the chapters, it displayed the japanese that i was renaming the titles with fine. but when i move onto the next step creating the layout, the titles with the japanese are now squares.
and also, i noticed that it numbered the chapter titles from 1-4 (the layout i chose was 4 chapters/page) on each page rather than numbering from 1-4 on the first page, 5-8 on the second, 9-12 on the 3rd, etc.. is there a way to change this numbering system? -
actually no worries bout the language problem...after i burned it and played it in my player, the japanese showed up fine. so i guess my question is only about the way nero numbers the chapters and how i can change how they are numbered or if i can turn off the numbering and have just the chapter titles. thanks.
and another thing i've noticed is that unlike in the final step of nerovision express before burning where you can do the preview and test it out with that remote control and select which chapter you want with the arrow buttons, that is not the case when i play it on my dvd player. i can only select which chapter i want to play by pressing 1, 2, 3 or 4 on my remote and to flip to the next page i have to press the 'next chapter' button (looks like >>|). when i press the same button to go to the next chapter during playback, it just takes me back to the menu. same thing happens with PowerDVD on my PC, so i'm guessing there's no way around it and it's a limitation with this program?
How to delete a menu & create/insert a new one with Nero Vision Xtra?
By snowseals in forum Authoring (DVD)Replies: 22Last Post: 26th Aug 2011, 23:03 -
Looking For Software to Create Menu- w/ Fade Transitions Between Chapters
By restmin in forum Authoring (DVD)Replies: 2Last Post: 13th Apr 2011, 16:36 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 11:36 -
Need to create video DVD with menu & chapters from VOBs. Any suggestion
By mr_tinka in forum Authoring (DVD)Replies: 2Last Post: 4th Feb 2008, 16:26 -
Can chapters created in Nero 6 show up in menu?
By wayney in forum Authoring (DVD)Replies: 2Last Post: 15th Jun 2007, 11:46
