I have a Sanyo DWM-360, which is listed to play all cdr + cdrw, but I have made 2 different movies on CDR (memorex 80min silver bottom cdrs) And all it says is 'NO PLAY' It also wont play any of my music cdr's (same type cdr). I have seen others list success's with this machine. What am i doing wrong? I am using Roxio Easy CD creator platinum and the VCD CDR's work perfectly in my dvdrom drive in power DVD 3.0 and Windows Media player. I am confused! I was about to buy a new Pioneer 334 thinking the sanyo must be the problem... ANY help would be GREATLY appreciated. jasperpso@hotmail.com
I tried using a Verbatim DataLifePlus 16X Blue bottome cdr and had slightly different result, this time it said 'NO DISC' with the memorex is said 'NO PLAY' If this helps at all. I again recorded it in Roxio Easy CD 5 creator platinum. i even did it in 4X like suggested by some guides.. please help!
jasperpso@hotmail.com -
I just tried a Memorex Platinum CD-RW and had same result 'NO DISC'
I am using CD Creator 5 platinum, i am going to try Nero 5.5.? but my computer plays all of these things fine, so i dont think that is the problem, but who knows...
Sanyo DWM 400 restart problem
By 389poncho in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Sep 2011, 09:24 -
Have a Sanyo DWM 390 dvd player that shows only black and white
By blackkat in forum DVD & Blu-ray PlayersReplies: 21Last Post: 28th Jan 2011, 20:24 -
Sanyo DWM-370, region hack question
By Akabane Kurodo in forum DVD & Blu-ray PlayersReplies: 5Last Post: 27th Aug 2009, 12:40 -
How can I find a Sanyo DWM-370 DVD Player???
By Akabane Kurodo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Jun 2008, 10:00 -
Can you interchange a xbox 360 hddvd drive between pc and 360?
By yoda313 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2007, 10:06
