Hi I use showbiz dvd burner but it ofter lag in sound. Can someone reccommend and east to use dvd burning software that's better.
Lagging sound won't be corrected with different burning software.
What is it that you are trying to burn? Is it a movie?
In which case the picture quality is probrably caused by poor media. If you are having problems particularly at the end ofmovies, try to slow the burn speed down and make the total size no larger than 4Gb.
If you are not burning movies and just short clips still try reducing burn speed.----Figured it out yet?
----What's that?
----Who's the best pilot!
TOP GUN (1986)
The best DVD burning software
By tarzan54 in forum DVD RippingReplies: 22Last Post: 1st May 2012, 05:11 -
By ingeborgdot in forum DVD RippingReplies: 6Last Post: 17th Sep 2011, 14:10 -
Anyone here use Burn4Free burning software for DVD?
By snafubaby in forum Authoring (DVD)Replies: 2Last Post: 22nd Feb 2009, 19:24 -
Looking for DVD Burning Software!
By mats.hogberg in forum DVD RippingReplies: 1Last Post: 29th Nov 2007, 09:52 -
Best DVD Burning Software for flagging 16:9?
By markannab in forum Authoring (DVD)Replies: 17Last Post: 4th Jun 2007, 13:09
