have transferred vhs to hdd and edited out unwanted segments....then burned dvd which has none of the "old segments" in the dvd but every now and then....at the end of some video clips....the playback stalls for a second or two (no smooth seamless flow of picture). I had copied the vhs tape in XP mode and recorded DVD in FR mode. It doesn't happen all the time only occasionally.
Also Erasing Scent from a play list ...doesnt work following the manual
1: press HDD
2: press Play List
3: use cursor
anybody has any suggestions.
Results 1 to 1 of 1
Panasonic DMR-HS2 power on failure
By rmhartman in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Feb 2012, 14:19 -
Panasonic DMR HS2 (Setup Mode?)
By philo in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Jun 2009, 12:14 -
Panasonic DMR-HS2 - shuts down when I try to record
By donmeyer2 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 4th Sep 2008, 22:35 -
Problem with Panasonic DMR-HS2
By rmhartman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Feb 2008, 15:07 -
Mpeg Video Wizard DVD: Burned to DVD-R, Plays back with hiccups.
By Giovannini in forum Newbie / General discussionsReplies: 13Last Post: 27th May 2007, 05:54
