Results 1 to 13 of 13
  1. The only one I know is SnatchIt. I want to make screenshot of scenes in a Divx, Xvid AVI file, which other software is available?
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    PowerDVD will and I think WinDVD as well.
  3. nope both don't do AVI, only MPGs.
  4. Banned
    Oct 2003
    Americas
    My PowerDVD 5 plays DV avi... how would you explain this...?
    I use it also for screen captures from miniDV (AVI file) material that I recorded. So, in short, yes it does work.
  5. Banned
    Oct 2003
    Americas
    sorry for double post... server issue
  6. I'm a Super Moderator johns0's Avatar
    canada
    Open the avi file with virtualdub and go to the desired frame and then click on video/copy frame source to clipboard and open paint and edit/paste image.
  7. Apparently PowerDVD 5 does not do DIVX,XVID AVIs, try it if you don't believe.
  8. johns0's advice works, thanks. Although if there are softwares that do this, let me know too.
  9. Member djmattyb's Avatar
    Dec 2001
    Seattle
    Last time I checked VirtualDub was software.
    dj matty b
  10. OK smarty pants, OTHER software.
    A Yellow Submarine
    TMPG can. You select it to only encode the frame you want and instead of making mpeg output you export to .bmp sequence and you will have a single .bmp picture.
    I don't think you should put djmattyb down for trying to help you .
  12. bsplayer does it too
    No, I'm from Iowa. I only work in outer space.
  13. I'm a Super Moderator johns0's Avatar
    canada
    Sounds to me you are looking for a program with one step click and pic taken.Not sure if you will find something that like that.
