  1. Hello all, has anyone successfully done batches of DVD-rips, or batches of DVD compressions (via DVD2ONEX)?
    Morpheus - I remember that I am here not because of the path that lies before me, but because of the path that lies behind me.
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    what do you mean BATCH?
    as in LOTS of differnet ones?
    or LOTS of the same ones?
    explain what your looking to do please....
  3. Sorry, I meant many different titles. Like if I could run:
    -Finding Nemo
    -Matrix 2
    -Enemy at the gates... etc.
    all through one batch process of DVD2OneX for example.
  4. Member galactica's Avatar
    Jan 2003
    not like your thinking i imagine
    click start and have it automatically do them down a list.
    not yet at least....
    you can do an equal amount that will fill your HD by manually selecting the VIDEO_TS and then choosing your format and pushing start.
    you can do that till your blue in the face
    but it wont automatically start the next one for you....
