I have a ? about burning,a aunt of mine use a burned movie of mine that wont play in her player(none of my movies wont play)but a cousin of mine uses the same disk an the same prog, an his work.I have the super drive +-4x he has a hp 200i burner we both use xcopy except he uses express,an i have platinum.we also use the same media maxell+r. Can some help me with an explaination uf what my be going wrong.maybe his burner does better quality burns than mine
Since it is important that your DVDs play on several DVD players, you may want to try using the UDF/ISO 1.02 mode for burning you next DVDs. This is how it is selected in Nero:
Hello. -
Thanks for the response its 4:00am where i'm at, so i'll try in the morning. Most of my movies play in players fine(except for 1 or 2 players).Also do you think this will help with my pc play my movies,they do fine in the burner but when i use them on my LG dvd on my computer they have reading problems also.Does the way you've told me make them more compatable or is it just about the same thing.One more question,I've had times when my xcopy plat. does the job that shrink can't do, but I like shrink better(doesn't have the anoying warning)Any suggestions to keep me from making coasters?
THANKS AGAIN 4 THE HELP.
The way around the rediculous warnings is to use DVD Shrink. But like you sed, shrink won't rip some movies. For situations like that, always have DVD Decrypter handy. Both programs are free. Probem solved. =)
Strange BD Rebuilder problem - Output files too small??
By YBS1 in forum Blu-ray RippingReplies: 1Last Post: 19th Sep 2009, 19:20 -
RCA small wonder problem.
By PK00 in forum Newbie / General discussionsReplies: 8Last Post: 5th May 2009, 15:15 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Burning small movie clips from camera(SD card) to dvd
By wesburnsco86 in forum Authoring (DVD)Replies: 6Last Post: 22nd Jul 2007, 15:09 -
Small problem psp 2.81
By the posse in forum ffmpegX general discussionReplies: 0Last Post: 7th May 2007, 15:52
