What is the best soFTware to capture decent video quality archives ( for make and see vcd in dvd )???
I have a PINNACLE STUDIO DC10, and I'm using the STUDIO DC 10.
I have a ATHLON / 750mhz / 128mb 10gig hd.
SPFC
I think you'll find that Virtual Dub is used probably most. I use AVI_IO because I find it less buggy. But everyone has a preference.
I've used both VirtualDub and AVI_IO. Hands down, AVI_IO
is the better app. Very rarely drops frames and is
simpler to use. VirtualDub drops lots of frames (for me
anyway) and does a lot of things I don't really need; AVI_IO focuses on doing one thing extremely well: capturing multisegment video. AVI_IO is definitely worth the $25.
vcddude -
AVI_IO is free if your captures are less then a certain time/size. There's a 3 file limit on the trail ver. So that's 12GB (3x 4GB) of AVI (for NTFS no limit).
AVI IO hands down is better for capturing. I'm not ripping on VirtualDub, I think it's an awesome program but you have to tinker with it alot just to set up a capture. Even then it drops alot of frames and is rather touchy about the settings you use. Both are great programs.
AV_IO for me without a doubt. Virtual Dub dropped loads of frames - AV_IO performs without a hitch on highest res and lowest compression.
Thats my 2pennthworth anyhow
Capturing Program
By vcd4me in forum Capturing and VCRReplies: 1Last Post: 20th May 2011, 10:02 -
what is the best program 4 capturing???i need one with good quality
By khalid81 in forum Capturing and VCRReplies: 1Last Post: 4th Aug 2009, 20:13 -
Best Capturing Program
By CLOUID in forum Capturing and VCRReplies: 2Last Post: 21st Feb 2009, 06:12 -
Choosing a Video capturing/editing program
By affiatati7 in forum Newbie / General discussionsReplies: 1Last Post: 5th Nov 2008, 07:05 -
Capturing program
By atvmxr in forum Newbie / General discussionsReplies: 2Last Post: 1st May 2008, 18:43
