I just purchased a Playstation 2. Before the kids tear into it and scratch up the game disks, I was wondering if I can use programs like DVD Backup and DVD2ONEX to make copies of the games. Any ideas/tutorials would be greatly appreciated.
Thank you.
Results 1 to 16 of 16
you just copy them directly over
put disk in
load toast, go to COPY and set to another drive for burn if you have 2 drives or go up to FILE and SAVE AS DISK IMAGE, then burn the disk image.
its been covered before so a search will yield more help.
i think you have to have some sort of modification to the ps2 for these disks to work... but i could be worng.
ps2daddy if you want to chime in ....
Yes, you will need a mod chip for the burned copies to work, you can order online if you are handy with a soldering gun, or if you look hard enough some private dealers will do the work for you.
You can use dvd backups made with process explained earlier in post with the following fliptop case.
Link is :
http://ps2fliptop.net/index.htm
Takes about 10 minutes to install, no soldering at all.
Brian -
I don't understand how one of those PS2Fliptop cases can help when you need a mod chip. What exactly do they do?
All a modchip does is feed the system startup info which makes the games playable. Using the fliptop, this startup info is instead placed on a disc which is used to "prime" the PS2, the disc is then swapped for a burned copy of the game. It means less soldering (there is a very small fifficult to reach and sensitive solder point on the back of the mobo.) and less chance of creating a $180 brick.
That makes more sense, but you mentioned it does require some soldering? And where would you get one of those "primer" discs?
Actually no soldering on the flip-top. Just too understated for my own good. By "much less" I actually mean none. As for the startup discs, they should be sold by whoever is selling the flip-top. (the cases are pretty useless without them) You'll need one for cd-rom games, and one for dvd-rom games.
My advice to you would be to forget about the flip top. Not all games will work with this method. They do have non solder mod chips, but they are a waste of time also.
I paid $150 (shipping included) to have mine professionally modded with the Messiah chip about a year and a half ago. It is still running strong and it plays every game I've copied. You just insert the backup, PS1 or PS2, and it boots just like the original.
I don't know about a Mac, but I have a PC and all I do is insert the original disc in one drive a blank DVD or CD in the my burner and click copy at 1x. Works perfectly every time. -
I just purchased a DVD burner (finallY) that is dvd +/- RW compatible. I have a PS2 and I modded it about 2 years ago... Works great with the GameShark and the CD-R games that I have played thus far. I am wondering if DVD based games require any sort of special attention or if you can just do a exact backup of the disk and they will work? Can someone please help me out? Thank you!
-B -
Yeah.. PS2 dvd backups are copied the same way. I have a DMS chip installed in a v7 US machine. The soldered chips are a lot more reliable than the flip top mods. Just use Alcohol 120, Nero, or similar disk copy software. They pretty much all work well for backing up.
Great. Thanks a lot for your help.. This is probably one of the best and most comprehensive websites I have ever been on, and has been an enormous help during my beginning period of "backing up" DVD's...
-B -
Um if you need to use Gameshark to swap for CD-R's...you've got a NeoKey or SBox. That means no DVD-R's. That mod was created for PSX, and PS2 games ripped to CD-R...I don't know anyone who can actually play DVD-R's that way with Gameshark.
I can't remember the exact version, but it is either the Neo 2.2 or 2.5... The manual and websites claim that it can play burned dvd's... I will have to give it a shot later, and I will let everyone know if it works or not...
Here is one of the websites it is referenced on...
http://www.chipzone.com/whichchip.cfm
-B -
Galactica summed it up in a nut shell thats all that you have to do but if you like the long drawn out versionOriginally Posted by starkisd
For those that need help with a mac
You need to use Toast Titanium 5.01 or higher
Open toast
If you just have a CD-RW and want to save it to your drive first
1. Select image copy (third option from the left at the top of the toast window)
2. insert CD game
3. Select "Save as image " under the file menu
4. Double Click on the image then Record image
(note you must have enough space on your hard drive to do this)
or
If you just have a CD-RW and want to just burn it
2. insert CD game
3. Click on record
it will ask you to place in a blank CD-R When ready
If you have a CD-RW and CD-Rom drive and want to copy on the fly
2. Drag CD to window
3. Click on record
If your cds are scratched there is a differnt method lemme
know if you have problems
Try burniing at a slower speed
How to make an image using astarte
1. Insert the disk and click on the “select all button” then hit save.
2. Make sure your preferences look like my attachment I included
How to patch games
Obtain PPF-o-Matic for the mac goto http://www.psxcopyworld.com
Obtain the required patch from that same site look in the psx patches and utilities sections
1. Open the program and select the Astarte iso you just created
2. Select the patch it is the file that has .ppf on the end
3. Click on apply patch
How to burn PS Game with audio tracks
1. Open toast 5 and select the “others” file cabinet in the top of the Toast window
2. Do a right click and select “Multitrack CD-Rom XA”
3. Then click on select and pick the iso file then click on “Add” repeat for each audio file and make sure that you put them in order
4. Select Record
Without Audio Tracks
1. Just double click on your Astarte image and it will put everything in the correct format in Toast Titanium 5 and click record
How to do DVD’s
Open toast
If you just have a superdrive and want to save it to your drive first
2. insert DVD game
3. Save as image
4. Record image (don't use burnproof)
or
If you just have a superdrive and want to just burn it
2. insert DVD game
3. Click on record
it will ask you to place in a blank DVD-R When ready
If you have a DVD-RW and DVD-Rom drive and you want to copy on the fly
2. Drag DVD to window
3. Click on record
I have burned at 2x on apple branded and pioneer media with no problem 4.37Gb took about 28 min after its copied to the HD takes about 20min to copy to the HD -
Originally Posted by MacTraderBoy
Fliptops will play about 85% of most games with no problems but depending on your ps2 you will have to use another boot disk in conjunction with the swap magic disks to play the rest. (you have to trick the ps2 into thinking it was never opend to swap games using a flip-top, knife swap, no - solder chip, or just leave you top off)
Here is a list of all the games that require an additional disk depending on your ps2 version
www.swapmagicfix.com
With the modchip you just stick a ps2 DVD-R game in like your normally would with no fuss no muss and they play every game with no problem. for psone CD-R games depending on the chip you have to hold down a button for 4 seconds before you insert the disk
Cost a little more to get a chip installed than to get a flip top and swap magic disks but if you had 3 games that are scratched beyond repair or broken the chip and install pays for itself since you dont have to rebuy those games. (also note that a disk doctor can fix about 85% of most scratched CD, DVD's)
The one catch is that wheter you use a flip-top or modchip you will not be able to play any of the current online games by using a backup but your original will always work you just have to disable your chip to garentee this (takes a 8 second button press)
(Basically any game after madden 2004 will have DNAS online protection)
Also its different strokes for differnt folks but I prefer a modchip anyday
If you need a reliable installer let me know send me a pm
Hope that helps
Is it possible to extract video files from XBox 360 / Playstation 3 games?
By Daniel_BMS in forum Capturing and VCRReplies: 0Last Post: 2nd Apr 2012, 23:15 -
Backup of Playstation 2 games
By Gerald Sr. in forum ComputerReplies: 5Last Post: 15th Jun 2008, 12:16 -
Playstation 2 plays games & DVD-Rs, but craps out on bought DVDs
By JustPlainDon in forum DVD & Blu-ray PlayersReplies: 3Last Post: 29th May 2008, 18:58 -
Backing up Games?
By LCE in forum Off topicReplies: 2Last Post: 24th Oct 2007, 00:45 -
How to copy Playstation 2 games
By avz10 in forum Off topicReplies: 21Last Post: 3rd Jun 2007, 10:12
