Results 1 to 11 of 11
  1. Hello. Just burned my first dvdr from a dvd. It plays in my norcent but not in my sony. But that is probably just the fact that the sony might not play dvd-r. I just have a couple of questions... I used DVDDecrypter to save to my HD then I used DVDSHrink to reduce the size of the whole DVD to fit on a 4.7...then used Nero to burn.
    1) The guides for nero say to transfer the video folder over to the nero burn area and then press write. In the guides there is a video and audio folder....I didnt have any video and audio folder after Decrypter was finished. I had a whole bunch of files. And the same when DVDShrink was finished...a whole bunch of files....so I took all of the files and transfered them over to nero and burned. Am I correct in doing this?
    2) Nero gave me two possible error messages before it would let me burn ...one was a compliance error and the other was was a read error and then it warned me that it might not play if burned in some dvd players.....I took this to be standard error messages. Am I correct about that? Or is it because I was missing something?
  2. when you burned with nero, did you select dvd-video mode?
  3. Yes I selected dvdmode then when Nero opens up to burn mode you have to add your files to the left hand side of nero....which has a audio and video folder that are empty. Do I put everything into the video folder and delete the empty audio folder?
    Jun 2001
    Richmond , VA
    Put all your files into the VIDEO_TS folder that Nero has created . Do not delete the AUDIO_TS folder , some players need this empty folder to be present . Now burn your compilation , you should not get any non-compliance warnings this time . Good luck .
    Keep it on the big cam !
  5. I suggest you do this very simple 1 step solution to all your problems.
    Take one of your Movie DVDs (the factory jobs), put it in your DVD drive, use Windows Explorer and view the contents of the disk. Just do this to about 5 of your Movie DVDs. You will see exactly what I meant above.
    The AUDIO_TS folder is usually empty. I'm not really sure why it's there because I've never seen it contain any files. The VIDEO_TS folder is where your movie and menus goes. Any other files located in the 'ROOT' of your MOVIE DVDs is probably nothing but junk.
    Sometimes I feel real good and will put an AUDIO_TS folder on my DVDs, sometimes not. They play the same for me either way. The AUDIO_TS folder is not needed.
    Using DVD Decrypter to rip your disks is a good idea. Many people use DVD Shrink and do both jobs at once, but I've read where that can be very hard on your DVD drive. DVD Shrink is a great program. I've seen it mess up before, but not often. It does a good job even when putting 2 movies on 1 DVD. I don't use NERO cause I don't like it. I use RecordNow DX.
    Good luck.
    Jun 2001
    Richmond , VA
    The AUDIO_TS folder is there because it is required for a dvd video to be fully compliant with dvd specs . Just because your equipment will play a disc without it does not mean everyones will . For full compliance it must contain an AUDIO_TS folder .
  7. Ok....Now I get this ..."DVDvideo files reallocation failed...The resulting dvd might be unplayable.". Anyone ever see that?
  8. found this in another thread. sounds like you might be missing some ifo files. When you rip the movie using dvd decrypter are you ripping all files or just the main movie?
    this is a nero log posted from another vcdhelp user:
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 10:03:20 AM
    ahead WinASPI: File 'C:\Program Files\ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 1/29/2003 10:37:36 PM
    Nero Version: 5.5.10.20
    Recorder: <SONY DVD RW DRU-500A> Version: 2.0e - HA 0 TA 1 - 5.5.10.20
    Adapter driver: <atapi> HA 0
    Drive buffer : 8192kB
    Bus Type : default (0) -> ATAPI, detected: ATAPI
    CD-ROM: <JLMS XJ-HD166S> Version: DS0F - HA 1 TA 0 - 5.5.10.20
    Adapter driver: <atapi> HA 1
    === Scsi-Device-Map ===
    DiskPeripheral : MAXTOR 6L040J2 atapi Port 0 ID 0 DMA: On
    CdRomPeripheral : SONY DVD RW DRU-500A atapi Port 0 ID 1 DMA: On
    CdRomPeripheral : JLMS XJ-HD166S atapi Port 1 ID 0 DMA: On
    DiskPeripheral : Maxtor 6Y120P0 YAR4 ultra Port 2 ID 0 DMA: ?
    DiskPeripheral : Maxtor 6Y080P0 YAR4 ultra Port 2 ID 2 DMA: ?
    AutoRun : 1
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 83886080 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Physical memory : 767MB (785896kB)
    Free physical memory: 445MB (456232kB)
    Memory in use : 41 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Enabled (1)
    Wizard: Off
    23.4.2003
    UDF/ISO compilation
    5:58:03 PM #1 Phase 112 File dlgbrnst.cpp, Line 1655
    DVD-Video files reallocation started
    5:58:03 PM #2 DVDREALLOC -24 File DVDVideoCompilation.cpp, Line 1114
    One or more files (mostly VOB file(s)) do not belong to the corresponding IFO file
    5:58:03 PM #3 Phase 115 File dlgbrnst.cpp, Line 1655
    DVD-Video files reallocation failed
    5:58:30 PM #4 Phase 132 File dlgbrnst.cpp, Line 1655
    DVD-Video files compliance ignored
    5:58:30 PM #5 Text 0 File Isodoc.cpp, Line 7579
    Iso document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : TRUE
    Multisession : FALSE
    Burning mode : DAO
    Mode : 1
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet : TRUE
    Allow pathdepth more than 8 directories : FALSE
    Allow more than 255 characters in path : FALSE
    Write ISO9660 ;1 file extensions : TRUE
    5:58:30 PM #6 Phase 111 File dlgbrnst.cpp, Line 1655
    DVD-Video files sorted
    5:58:30 PM #7 Text 0 File Reader.cpp, Line 115
    Reader running
    5:58:30 PM #8 Text 0 File Writer.cpp, Line 125
    Writer SONY DVD RW DRU-500A running
    5:58:30 PM #9 ISO9660GEN -11 File geniso.cpp, Line 4563
    First writeable address = 0 (0x00000000)
    5:58:31 PM #10 ISO9660GEN -11 File geniso.cpp, Line 4563
    5:58:31 PM #11 Text 0 File Burncd.cpp, Line 3726
    Turn on Disc-At-Once, using DVD media
    5:58:31 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 672
    Setup items (original item values)
    0: TRM_DATA_MODE1 (CTransferItem)
    2 indices, index0 (150) not provided
    original CD pos #0 + 1889568 (1889568) = #1889568/419:54.18
    relocatable, CD pos for caching/writing not required/required, no patch infos
    5:58:32 PM #13 Text 0 File DlgWaitCD.cpp, Line 215
    Last possible write address on media: 2298495 (510:48.45)
    Last address to be written: 1889567 (419:56.17)
    5:58:32 PM #14 Text 0 File DlgWaitCD.cpp, Line 220
    Write in overburning mode: FALSE
    5:58:32 PM #15 Text 0 File DlgWaitCD.cpp, Line 1657
    Recorder: SONY DVD RW DRU-500A, Media type: DVD-R
    Disc Manufacturer: RITEKG - 04
    Disc Application Code: 64, Disc Physical Code: 193
    5:58:32 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 824
    Prepare recorder SONY DVD RW DRU-500A for write in cue-sheet-DAO
    DAO infos:
    MCN:
    TOCTYPE: 0x0 Session Closed, CD fixated
    Tracks 1 to 1:
    TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 -424824832
    5:58:32 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 672
    Setup items (after recorder preparation)
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1889568 blocks [SONY DVD RW DRU-500A ]
    5:58:32 PM #18 Phase 24 File dlgbrnst.cpp, Line 1655
    Caching of files started
    5:58:32 PM #19 Phase 25 File dlgbrnst.cpp, Line 1655
    Caching of files completed
    5:58:34 PM #20 Phase 36 File dlgbrnst.cpp, Line 1655
    Burn process started at 4x (5,520 KB/s)
    5:58:35 PM #21 Text 0 File ThreadedTransferInterface.cpp, Line 1978
    Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
    5:58:35 PM #22 Text 0 File DVDR.cpp, Line 1364
    Recording mode: Sequential Recording Mode
    5:58:35 PM #23 Text 0 File Mmc.cpp, Line 17693
    Set BUFE: Power-Burn -> ON
    5:58:35 PM #24 Text 0 File DVDR.cpp, Line 1478
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    5:58:35 PM #25 Text 0 File Cdrdrv.cpp, Line 7863
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD-R (2), Part Version: 5
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 0 h
    End Sector Number in Layer 0: 0 h
    Data in Burst Cutting Area (BCA) does not exist
    Media Specific:
    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    5:58:37 PM #26 Text 0 File Writer.cpp, Line 316
    17:58:37.952 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    5:59:46 PM #27 Text 0 File Writer.cpp, Line 316
    17:59:46.999 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    5:59:47 PM #28 Text 0 File Writer.cpp, Line 316
    17:59:47.983 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    5:59:48 PM #29 Text 0 File Writer.cpp, Line 316
    17:59:48.030 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    5:59:48 PM #30 Text 0 File Writer.cpp, Line 316
    17:59:48.077 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    5:59:48 PM #31 Text 0 File Writer.cpp, Line 316
    17:59:48.124 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    5:59:48 PM #32 Text 0 File Writer.cpp, Line 316
    17:59:48.171 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    5:59:48 PM #33 Text 0 File Writer.cpp, Line 316
    17:59:48.218 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    5:59:48 PM #34 Text 0 File Writer.cpp, Line 316
    17:59:48.249 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:00:24 PM #35 Text 0 File Writer.cpp, Line 316
    18:00:24.936 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:00:24 PM #36 Text 0 File Writer.cpp, Line 316
    18:00:24.983 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:01:02 PM #37 Text 0 File Writer.cpp, Line 316
    18:01:02.921 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:01:40 PM #38 Text 0 File Writer.cpp, Line 316
    18:01:40.890 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:01:53 PM #39 Text 0 File Writer.cpp, Line 316
    18:01:53.421 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:01:54 PM #40 Text 0 File Writer.cpp, Line 316
    18:01:54.968 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:01:55 PM #41 Text 0 File Writer.cpp, Line 316
    18:01:55.015 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:02:18 PM #42 Text 0 File Writer.cpp, Line 316
    18:02:18.905 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:02:27 PM #43 Text 0 File Writer.cpp, Line 316
    18:02:27.452 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:02:56 PM #44 Text 0 File Writer.cpp, Line 316
    18:02:56.858 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:02:56 PM #45 Text 0 File Writer.cpp, Line 316
    18:02:56.905 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:03:04 PM #46 Text 0 File Writer.cpp, Line 316
    18:03:04.452 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:03:30 PM #47 Text 0 File Writer.cpp, Line 316
    18:03:30.827 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:03:31 PM #48 Text 0 File Writer.cpp, Line 316
    18:03:31.452 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:03:34 PM #49 Text 0 File Writer.cpp, Line 316
    18:03:34.843 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:04:12 PM #50 Text 0 File Writer.cpp, Line 316
    18:04:12.811 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:04:16 PM #51 Text 0 File Writer.cpp, Line 316
    18:04:16.952 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:04:18 PM #52 Text 0 File Writer.cpp, Line 316
    18:04:18.171 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:04:50 PM #53 Text 0 File Writer.cpp, Line 316
    18:04:50.811 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:05:28 PM #54 Text 0 File Writer.cpp, Line 316
    18:05:28.780 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:06:04 PM #55 Text 0 File Writer.cpp, Line 316
    18:06:04.843 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:06:04 PM #56 Text 0 File Writer.cpp, Line 316
    18:06:04.890 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:06:06 PM #57 Text 0 File Writer.cpp, Line 316
    18:06:06.749 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:06:44 PM #58 Text 0 File Writer.cpp, Line 316
    18:06:44.718 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:06:44 PM #59 Text 0 File Writer.cpp, Line 316
    18:06:44.765 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:06:57 PM #60 Text 0 File Writer.cpp, Line 316
    18:06:57.624 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:07:22 PM #61 Text 0 File Writer.cpp, Line 316
    18:07:22.655 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:07:52 PM #62 Text 0 File Writer.cpp, Line 316
    18:07:52.530 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:08:00 PM #63 Text 0 File Writer.cpp, Line 316
    18:08:00.640 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:08:00 PM #64 Text 0 File Writer.cpp, Line 316
    18:08:00.702 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:08:19 PM #65 Text 0 File Writer.cpp, Line 316
    18:08:19.202 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:08:19 PM #66 Text 0 File Writer.cpp, Line 316
    18:08:19.827 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:08:38 PM #67 Text 0 File Writer.cpp, Line 316
    18:08:38.593 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:09:00 PM #68 Text 0 File Writer.cpp, Line 316
    18:09:00.405 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:09:16 PM #69 Text 0 File Writer.cpp, Line 316
    18:09:16.561 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:09:16 PM #70 Text 0 File Writer.cpp, Line 316
    18:09:16.624 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:09:54 PM #71 Text 0 File Writer.cpp, Line 316
    18:09:54.530 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:10:09 PM #72 Text 0 File Writer.cpp, Line 316
    18:10:09.296 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:10:09 PM #73 Text 0 File Writer.cpp, Line 316
    18:10:09.374 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:10:31 PM #74 Text 0 File Writer.cpp, Line 316
    18:10:31.999 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:10:32 PM #75 Text 0 File Writer.cpp, Line 316
    18:10:32.499 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:11:10 PM #76 Text 0 File Writer.cpp, Line 316
    18:11:10.452 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:11:10 PM #77 Text 0 File Writer.cpp, Line 316
    18:11:10.483 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:11:17 PM #78 Text 0 File Writer.cpp, Line 316
    18:11:17.108 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:11:18 PM #79 Text 0 File Writer.cpp, Line 316
    18:11:18.624 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:11:18 PM #80 Text 0 File Writer.cpp, Line 316
    18:11:18.702 - SONY DVD RW DRU-500A : Queue again later (Intervall : 11msec)
    6:11:43 PM #81 Text 0 File WriterStatus.cpp, Line 115
    <SONY DVD RW DRU-500A > start writing Lead-Out at LBA 1889568 (1CD520h), lenght 0 blocks
    6:11:43 PM #82 Text 0 File ThreadedTransfer.cpp, Line 219
    all writers idle, stopping conversion
    6:12:31 PM #83 Phase 37 File dlgbrnst.cpp, Line 1655
    Burn process completed successfully at 4x (5,520 KB/s)
    6:12:31 PM #84 Text 0 File Scsicmd.cpp, Line 406
    SCSI not using temporary buffers
    20 out of 20 temporary buffers allocated
    Existing drivers:
    File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 7/17/2002 9:05:10 AM
    File 'Drivers\atapi.sys': Ver=5.1.2600.0 (XPClient.010817-1148), size=86656 bytes, created 8/23/2001 12:00:00 PM (Adapter driver for rec)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
  9. What the h@ll was that!
    Upgrade NERO to the newest version. By what I've found that should fix it.
    Good luck.
  10. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    1) Use DVDDecrypter in ISO mode - Read then Write....simple....if the DVD is NORMAL size.
    2) Use DVDShrink to re-author the dual layer DVD to fit to a DVDR. Use IFOEdit to create an image of the files DVDShrink created....then burn in DVDDecrypter's ISO Write mode.
    DVDDecrypter - FREE
    DVDShrink - FREE
    IFOEdit - FREE
    3) Use Nero to burn CD's.
  11. Thanks for all the replies. They helped me alot. The nag messages in nero where because I didnt have the right video folder created. Nero didnt like that. When I did everything step by step I saw that the folder wasnt correct....and also when I did everything my sony dvd player played the movie without a problem. I used Decrypter Dvd2one and Nero to burn. Thanks everyone.
