I've got an AVI who's size is 608x240 with a framerate of 23.976. Using TMPGEnc, what settings should I use to convert this file for widescreen format? I'm totally lost. I need to make this ready for DVD burning.
Thanks in advance.
use NTSC film as your source (it should pick this automatically) and choose the output you want, I always choose 4: 3 retain aspect ratio but its up to you. Why run a short test to see what the output is like?
Most of the time if you set the source aspect to VGA 1:1 and set the other to 4:3 as stated above, the video will look right. You can tell by hitting start and looking at the video preview window.
Joining two different sized video files
By nominalgrevious in forum Newbie / General discussionsReplies: 8Last Post: 7th Mar 2012, 16:38 -
Photoshop: composition sized for printing
By kippard in forum ComputerReplies: 10Last Post: 10th Jan 2008, 11:18 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Settings in ffmpegX for odd size .avi files
By sknox in forum ffmpegX general discussionReplies: 2Last Post: 8th Jul 2007, 22:32 -
Poorly sized video on converting VCD to DVD
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2007, 01:39
