Hello, I have an Abit NF7-S Rev. 2.0 with a 2500+ Barton not overclocked. At idle it runs about 40'c and while on the internet it gets up to 51'c. Is this normal? I get too scared to play games or do anything that takes full load since I cant monitor it while doing so.
Absolutely normal, My XP2800 ran at 80 degrees C with the crappy standard heat sink. Changed the sink went down to 60 degrees. Looking to get it lower with a better heatsink and fan which I will get after christmas.
According to AMD ~90 degrees Celsius is considered hot. I see mine peak at 54 after hours of encoding with #1 running at a few degrees cooler than the other one.
CPU Temp.
By HotDamn! in forum ComputerReplies: 33Last Post: 8th Mar 2010, 13:21 -
Is it safe to sell our free cell-phones? Also, is it safe to BUY?
By siratfus in forum Off topicReplies: 3Last Post: 12th Dec 2009, 15:30 -
Speedfan and the various temp's ???
By blinky88 in forum ComputerReplies: 10Last Post: 19th Jun 2009, 12:37 -
Processor Temp Help
By mikayd in forum ComputerReplies: 9Last Post: 29th Dec 2008, 21:01 -
CPU Temp
By Willy5157 in forum ComputerReplies: 4Last Post: 9th Feb 2008, 20:22
