Trying to convert from an asf to and mpg but audio seems to be slightly out of synch. I'm a little new to this so any help, suggestions or pointers would be much appreciated.
Also, a question about S-Vcd's. Can any mpg which may have previously been an avi (divx) be converted into a S-Vcd? I use to burn mpg's as vcds. Can S-Vcds be played in most Dvd players which support Vcd's? Are S-Vcds significantly better or a much larger size?
Thanks in advance
Why does everyone use tmpgenc when LSX is 1.5 - 2 times as fast..?..j/w
umm maybe because lsx gives you an audio problem to where you cant convert audio
I just tested Ligos LSX and find that with the same source file I get better quality results from TMPGEnc, and for free. And for me quality is more important than speed, otherwise I would just do direct capturing to MPEG1.
asf to MPG conversion
By kshavo in forum Video ConversionReplies: 1Last Post: 15th Oct 2010, 04:14 -
need help converting .asf to h264 .mp4
By hydra3333 in forum Video ConversionReplies: 3Last Post: 12th Sep 2010, 07:53 -
converting asf to avi
By projecttemp in forum Video ConversionReplies: 2Last Post: 3rd Aug 2008, 08:40 -
converting asf to avi problem
By konig in forum Video ConversionReplies: 1Last Post: 6th Mar 2008, 15:37 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 10:07
