Hi.
I have a DVD, which holds a video of #3 GB (audio + video). I would like to extract the video MPEG-2 stream without audio (which is AC3) into one single file (*.mpg).
How can I do that?
I tried DVD Decrypter, but there I get *.vobs and not an *.mpg file.
The reason I would to do that is that I want to keep the original MPEG-2 stream, without reencoding the movie (= loss of quality).
Thanks!
Results 1 to 15 of 15
TMPGEnc DVD Author will extract an MPG file. As far as without Audio...you will have to de-multiplex it using TMPGEnc and then multiplex it with no audio.
Although I don't know why you would need to do that. What are you trying to accomplish.
Hope this helps -
The audio will still be found in a VOB. I'd imagine ripping the right VOB, and selecting the correct stream (in stream processing mode) with DVDDecrypter would do the trick?
...and don't go grave-robbing (waking up a 3 year old thread) - start a new thread instead - it's really easy.
/Mats -
Get Smartripper and use the stream processing option to demux to separate file.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Are you sure that SmartRipper extracts the audio from a _menu_? It looks like it works the same way as DVDDecrypter, i.e. it just demuxes the movia data (audio and video), and doesn't allow access to the menu sound.Originally Posted by SLK001
Thanks, -
DGIndex extracts the sound of the video file (movie), not the one of the menu contained inside the VTS.
Of course it extracts the menu audio. I just tested it with no problem. I don't know why you keep talking about a menu VTS. A menu vob is always numbered with a "0", so typically it'll be VTS_01_0.VOB. The other vobs within that VTS will have different numbers, like VTS_01_1.VOB, VTS_01_2.VOB, etc. Load the VTS_01_0.VOB, if that's the one with the menu, and Save Project
Just make sure you have Audio->Output Method->Demux All Tracks checked. It's default, I'm pretty sure. -
You were right. I wasn't aware that _0 stands for the VTS menu. I was able to extract the audio track. However, 30 seconds were recorded (1250 frames MP2 à 24 ms), but DGIndex only extracted 1245 frames !?Originally Posted by manono
Where's the error. Does DGIndex not extract all frames, or is the DVD badly authored (DVD-lab PRO)?
Thanks, -
You are confused. 30 seconds at 30fps is only 900 frames.
Forgot to mention ... this is PAL (25 fps). Sorry!Originally Posted by SLK001
Besides that ([DVB-S] PAL, MPEG-2, MP2, AC3), video frames last 40 ms, MP2 audio 24 ms and AC3 32 ms. All this ... to the best of my knowledge.
Anyhow ... 5 frames are missing.
MPEG-2 VOBs trouble in VirtualDub
By shmizan in forum Video ConversionReplies: 4Last Post: 16th Apr 2010, 10:35 -
Extract from avi file and add to existing mkv file
By pathumx in forum MacReplies: 6Last Post: 8th Apr 2010, 19:57 -
Simple VOBs to DVD-ready MPEG 2 HOW?
By Flarch in forum MacReplies: 8Last Post: 6th Jan 2009, 09:34 -
Extract part of an audio file into a new file without rencoding?
By therock003 in forum AudioReplies: 4Last Post: 19th Oct 2007, 17:32 -
How to extract a .wmv file from inside a .dat file
By Toastie in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 23:06
