Since the price fall of all radeon cards i have a choice between the all in wonder radeon or the 64mb VIVO card.... what are the differences apart from tv... does the 64mb work towards mpeg encoding or is it just of benifit to gaming?
if you go with any one of these card make shore they have S-video input if you want to capture
I'm also buying a new computer and have decided to buy a ATI Radeon card. I haven't been able to select that should I buy ATI Radeon 64MB DDR AGP VIVO or ATI Radeon All-In-Wonder 32MB DDR AGP. Is there anything else different between the cards except that AIW has integrated tuner and VIVO has 32MB more memory?
Is there any differences in VideoIn quality (I'm going to input the picture from SVHS video and I don't need the tuner) or is the picture quality exactly the same? Does anyone know?
BTW: VIVO means VideoIn/VideoOut -
Hi nfl2k2, I am using AIW 32MB DDR that cames with both S-Video and standard Video inputs. The S-Video capture of my Hi8 tape are much better then the Yellow cable.
thanks... the cards are the same in that they both use the same capture chip... the VIVO has a composite in which should be fine for getting scart in? (i think, quality is good yes or no?)
what i want to know is does the 64mb and the DDR and the mhz etc had any bearing on the ability to capture mpeg or is it just of use to the 3d gaming aspect
i think i will go for this card anyway as it is by far the cheapest option
there will be no more ati VIVO cards (boo) as they want you to buy the 8500DV which will cost a lot of money ($500)
oh well -
If you want the best card on the market go with the Radeon 8500. In pre release reviews it beat the Geforce3 Ti500. And you can get the Radeon 8500 for about 240 dollars. If you really dont want to spend that much money, go with the Radeon 7500 (instead of Radeon VIVO), they are real similar cards but the 7500 has the newer technology.
What sucks is that i spent 280 for a Gainward Geforce3, then a week later the Radeon 8500 comes out, which is a better card, and its cheaper.
If you want an AIW card, id say wait for the Radeon 8500DV
Sound with ATI AIW 9800 Pro
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 8th Aug 2010, 07:02 -
Weird Interference ATI AIW Pro
By Tom Saurus in forum ComputerReplies: 8Last Post: 7th Aug 2010, 10:52 -
Clean uninstall of ATI AIW 9600
By justin81 in forum Capturing and VCRReplies: 3Last Post: 23rd Dec 2009, 11:41 -
ATI AIW 7500 64M Replacement?
By TaranScorp in forum Capturing and VCRReplies: 20Last Post: 6th Aug 2009, 12:56 -
ATI Aiw card in Linux?
By Nelson37 in forum LinuxReplies: 9Last Post: 10th Apr 2008, 14:25
