can someone tell me how to convert a 480X480mpg to dvd compliant format? if there is a guide please point me in the correct direction. thanks.
Try svcd2dvd and svcd2dvdmpeg ( and maybe svcd2mpeg ).
There are a few basic ways of doing it.
1) Patch the header of the SVCD to fake it out as 1/2 D1 (closest DVD resolution). Then all you have to do is resample the audio to 48 Khz. TMPG Author will do the Aduio for you during authoring.
2) Re-Encode to a stnadard resoltuion. This takes a lot longer, and introduces more artifacts.
3) If you lucky enough to have a player that supports MPEG's in ISO mode, then you can simply copy the 2-4 SVCD's to a folder on a DVDR and play that.
Generally speaking it's easier to work from your original DVD's.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
The only way to convert such a video to DVD compliant is to re-encode. I would reccomend using 1/2 D1 resolution (352*480). There will be some quality loss, but if you keep the average bitrate at the same as the source it should be minimal. There are plenty of guides in the convert section.
However, some DVD players will play 480*480 in DVD-Video format. If you want to give that a try, take a look at SVCD2DVDMPG and the guides that use it.
convert mp4 to mpg / DVD (mac)
By tou in forum ffmpegX general discussionReplies: 2Last Post: 29th Aug 2010, 18:57 -
How can I convert a DVD to mpg with subtitle?
By szalaikornel in forum Video ConversionReplies: 4Last Post: 4th Feb 2009, 12:58 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 08:47
