Hi, I need some help,
Ive tried to flash my Sony DW-U10A_to_DRU-500A and it has'nt worked, I desperatly need some help how to get it working again since now it doesn't show as a Sony dvdr drive at all and doesn't work, Can someone please offer some advice or links as to how to reflash this drive so it works again.
Mark.
Sorry to hear your Sony is giving you problems. Go here for an extensive discussion on the topic. http://forum.rpc1.org/viewtopic.php?t=16646&highlight=&sid=7c478594ada132fdd83655353ca89a6f
You should be able to flash it back to a dwu-10a easily.
Alot of firmware for your drive here...use the links in english in the yellow..
http://www.ued.janis.or.jp/~jabawock/down.html -
With the downloads from the previous links, how do you execute them from win xp?
Thanks -
Why were you stupid enough to flash your drive with the wrong firmware?? Did you think you could change a 4x to an 8x ??
Another thing is why did you flash it for? I mean I purchased a 500ax and I NEVER flashed it and it works flawlessly and it burns 2x and 4x with no trouble at all...
Because I thought it would enable me to use a broader range of Cheaper discs!
Anyway Thanks to ramair23 its working fine now
as a 500a drive with 320 g firmware.
Stupid Flanders with his stupid iLoHD04 problems!
By Batchman in forum DVD & Blu-ray RecordersReplies: 33Last Post: 4th Mar 2011, 18:41 -
i know this sounds stupid but...
By cthuggha in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 30th May 2009, 10:02 -
Avidemux .. I must be stupid
By bvdd in forum Newbie / General discussionsReplies: 9Last Post: 1st Mar 2009, 18:06 -
Probably a stupid question, BUT...
By HmNtr in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 7th Dec 2008, 13:22 -
New to burning: Am I stupid?
By Eat Right in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2008, 13:47
