Hi all,
I have read and tried many techniques (much thanks to everyone) with various levels of failure and success and finally tried the following:
a) Decrypted using DVD Decrypter to the HD
b) Used DVD Shrink on the files (from DVD Decrpyter) to shrink the DVD to fit onto one DVDR.
c) Burnt the disk using Nero 6.
When I play the DVD (DVD-RW) I get no sound.
I am using Ulead and Real PLayer to test the DVD.
However when I goto the DVD and open the a VOB file with ie Real player the sound plays?
This means that both the audio track and the codecs must be right otherwise the VOB would not play with audio, right???
My guess is that it must be some other file ie one of the .ifo files.
Any Ideas?![]()
I removed the DTS audio option and then performed the Shrink and that worked.
Thanks a million.
I guess that the disk(s) that I cannot hear will actually work witha DTS amplifier.
I also used the DVD Shrink 1.03 and that also worked. It must not use the DTS option.
Cheers,
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 12:35 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14
