Is there a way to convert a WMV file (created by Windows Movie Maker) to MPG format while keeping the same size and quality please? The reason I need to do that is that many internet browsers do not seem to support WMV and hence the video clips cannot not be viewed.
I think that is a pretty tall order. WMV is highly compressed and consistently provides smaller yet reasonably high quality (given the file size) files, about on par with DivX.
I have used Windows Media Encoder many times to capture Video from VCR / Camcorder and I have never successfully converted a WMV file to MPG without practically a 25-50% increase in size. In addtion, the mere fact that you are converting from 1 format to another will result in a loss of quality.
That said -- give it a try. TMPGenc will work with WMV files (select ALL FILES TYPES *.*) and provides as good or better a result as any other product with regards to video quality.
-- You may need to download and install the WM9 codecs from Microsoft, if you find that TMPGenc does not recognize the encoder/decoder.
stand alone MPG/WMV player
By confused2011 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 28th Nov 2011, 22:26 -
WMV and MPG to Xvid or MPG2?
By videohalp in forum Video ConversionReplies: 2Last Post: 28th Sep 2008, 00:16 -
WMV/MPG problems
By Metallian MetalGod in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2008, 22:35 -
.flv to .wmv or wmv. to mpg
By LITEONDVD in forum Video ConversionReplies: 5Last Post: 29th Jul 2007, 19:02 -
Converting WMV to MPG
By Datahead in forum Newbie / General discussionsReplies: 3Last Post: 22nd May 2007, 15:08
