Hi all I am new to this task but am trying really hard to burn a avi movie. from what i understand from the faq and forum is i need it to be a mpeg which i did using TMPGEnc but when i try to play it i get no picture only audio. Is there something i missed in the directions or could i just be using a bad avi file. or am i going completely the wrong direction. please HELP!!!!!
Yo will NOT get any help by double posting the same post...that is extremely annoying
what do you mean by duble posting?
i only posted it once and i could not find any other posting using the search method if i did somethin wrong im sorry -
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=63014&forum=3
Do you try to play it with a software player or a standalone dvd player? How did you encode, I mean, what are your encoder settings?
You are right, if you want to create a (S)VCD, you have to encode to MPEG. If you just want to watch it on PC, DivX might be better. -
i am trying to play on a standalone player
i believe it is nstc but im not sure what should i be using.
my dvd player says it does not support pal and from what i can tell from the org avi the video frame rate is 12.5 frames per second (i believe this is the fps?)the data rate is 44kb/sec any and all help is appreciated
Video/audio TS files convert to an uploadable MPEG video
By Prizm007 in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2011, 14:30 -
H264 TS and MPEG Audio in AVI
By flash_49 in forum Video ConversionReplies: 9Last Post: 30th Oct 2009, 11:43 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
AVI files - MPEG Layer-3 - audio conversion?
By ChoonyFish in forum Video ConversionReplies: 6Last Post: 7th Feb 2008, 08:27 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 00:23
