I have Forty Two VXplus and when I do the auto disc feature, I get an output file 100-200mb less than 700mb and small resolution. How can I make it to have the best bitrate and resolution and fill up a 700mb CD totally. Thanks.
use another bit rate calulator (such as one in ffmpegx)
or just do trial and error until you reach the best for 1 cd using manual typed in rate in fortytwo
if you do that try setting up a ratio of what you started with and got using forty to to what you would like to get and use that solved value for your new bitrate.
Auto DVD Rip - Put the disc in the tray and the program does the rest
By dw-wizard in forum DVD RippingReplies: 8Last Post: 17th Feb 2012, 00:54 -
PowerDirector auto-transition? auto-audio fade?
By yic17 in forum EditingReplies: 1Last Post: 16th Mar 2011, 15:59 -
Auto-load subtitles from a Blu ray Disc
By jimhoofd in forum SubtitleReplies: 4Last Post: 9th May 2010, 17:25 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 09:59 -
Auto-GK file output, low quality despite large size
By Fallout1 in forum Newbie / General discussionsReplies: 10Last Post: 5th Oct 2009, 19:27
