hi
i often wondered if it was possible to increase the video resolution
i ask this because i have mpg video files ( 352x240 ) that i want to convert in divx files ( 720 x 576 )
is it possible ?what apps do i need ?
does the video quality depend only on the resolution?
thans for the help
Virtualdub will let you resize your video. Once you have your video compression figured out just select Filters in the Video menu. Then click "add" and then "resize" and finally set your new resolution size by clicking "configure". Under Filter Mode, make sure you select Precise Bicubic.
HD Video Conversion??
By moobox in forum MacReplies: 6Last Post: 4th Feb 2010, 17:42 -
best video conversion
By katray98 in forum Video ConversionReplies: 4Last Post: 10th Jan 2010, 11:41 -
Video Conversion
By bojan99 in forum Blu-ray RippingReplies: 3Last Post: 5th Dec 2009, 03:44 -
AI for video conversion
By Rendrick in forum Newbie / General discussionsReplies: 0Last Post: 7th Jul 2008, 14:52 -
Video CD to DVD-video conversion
By mingul in forum Video ConversionReplies: 3Last Post: 24th Jan 2008, 04:12
