I converted a file to mpg 2 under the dvd option. But it out puts to files a video file and a sound file how do I burn that to dvd use arcsoft showbiz dvd![]()
I use TMPGEnc Author, not really familiar with Showbiz. What you need is an authoring program to prepare your files for DVD format. You can download a trial version of TMPGEnc Author. Read the guides on authoring to the left. If Showbiz can do authoring, the process will be similar. TMPGEnc Author, at least, can also do the burning.
Does TMPGEnc re-encode when burning to blu ray?
By daysaf00 in forum Authoring (Blu-ray)Replies: 1Last Post: 17th Mar 2012, 03:12 -
Problem burning a project on to a DVD from TMPGEnc Author 3
By vhsal in forum Authoring (DVD)Replies: 5Last Post: 21st May 2011, 19:25 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 20:40 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
