Hi,
I am in the process of making a home movie using Pinnacle Studio. I have taken a compliation of photos and videos and music and I am going to burn it on a dvd. My cannon digital camera takes short AVI movies which I would like to incorporate into my movie. I understand that the quality will be poor at best when viewed on a tv screen, but theses avi files are of my sons first few seconds in this world and it is very important to me.
So here is the problem. When I try to render the video in pinnacle I get a message that says " The selected clip has a non-standard fram rate that cannot be encoded to MPEG" Is there a way to convert this avi file into a framerate that pinnacle would accept?
I just did and tmpge separated the audio files from the vido files. Is it supposed to do that?
You had the setting wrong. At the bottom of the main screen under Stream Type, select System [Video & Audio].
Hello.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
