I have a panny DMR-80 DVD recorder but its lack of an IR blaster has really slowed me down on scheduled programs (you need to setup timer on for example your dish unit and then again on the dvd recorder)
Anyway, I would like you all to comment as to what you recommend for a PVR and keeping the cost under $300-400 assuming that you already have a pretty robust computer.
-Capture card with real time mpeg 2 recording (e.g. Hauppauge WinTV-PVR-250
- Software to go with above for the capture, recording, scheduling,...
- IR blaster (e.g. "Myblaster") to be integrated with above so that once you schedule a "recording" say with Titantv.com, it would change the channel on you cable box/dish receiver automatically.
Ultimate goal is to have high quality mpeg 2 files that are DVD comliants and are ready to be authored in as automatic way as you can have it
Thanks,
Try look at SageTV and Beyond TV they both work with Dish receiver and both them have build EPG so there no need for Titantv there are other IR Blasters
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Can someone Please Recommend a good software to create Gif from video?
By dudeme13 in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2011, 14:31 -
can you recommend good ripping software ?
By Bansaw in forum DVD RippingReplies: 2Last Post: 14th Sep 2010, 19:39 -
Trying to select PVR software for my capture card.
By GLE3 in forum Capturing and VCRReplies: 7Last Post: 14th Apr 2010, 19:03 -
WinTV-HD software needed (not HVR, PVR, Nova, but for original PCI card)
By cybertheque in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 01:21
