  1. OK im using smart ripper and ifo edit so i rip my dvd and use ifo edit but when i burn it or preview it the ending always freezes on certain dvds i have comed across this problem with 28 days later and pirates of the caribean and bringing down the house i was wondering if anyone knows why the ending freezes on some of the dvds i burn like the last few mins it freezes but the talking keeps on going on if you can help me please do so
  2. So it doesn't do that on all the DVDs you've burned, just some? Sounds like a media problem. You didn't say what media you're using, if you don't know exactly, use DVDINFOpro to find out.
    You could try shrinking your file further to about 4GB, sometimes that helps with dicey media. Or burn with DVDDecrypter. Try different things, something will work assuming no faulty hardware.
    Pull! Bang! Darn!
  3. well im using nero to burn my movies and preview them before i burn on power dvd and i dont know what to do dvd decrypter seems complicated my friend he uses nero to rip and burn so if you know about that let me know
  4. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    What he means is its most likely the brand of blank DVD you are using. He suggested you test one and find out its brand. 99% of media freeze/pause issues turn out to be crummy disc.
  5. Hello
    Try using DVDShrink, there is a link on this website and also a very good guide. This tool can be used to pull any section of the movie to your hard drive. If you want a complete replica of the original disk you will have to use high compression which can effect quality. I OTOH am only interested in the movie when I backup so I copy just that section. This way I can keep the resulting file at the 4Gb mark and still have a low compression level so therefore a good quality output.
    I have had the jumpy disks at the end and they are because of poor quality media. As advised try and get the output to about 4gb mark and also reduce burning speed, this has saved several of my poor quality disks from being a complete waste.
    Also, don't be afraid of new software, the guides on this site will tell you all you need to know.
    ----Figured it out yet?
    ----What's that?
    ----Who's the best pilot!
    TOP GUN (1986)
