I've read some people who want to edit more with the E60 can use a relatively cheap Panasonic player that will play RAM discs and dub their RAMs to DVD-R.
My question is will that result in any noticeable loss in quality? Mainly using XP or SP mode?
Also, I've read that when dubbing from tape or Lasrdisc, you should use the Yellow composite cable and not the S-Video.
What about dubbing from another DVD? Should you still use the Yellow?
I'm sorry for all the questions, it's just that I've been lurking on this board for many months now, and I've finally gotten a DVD recorder.
Also, if you try to flex record something on a new disc, and set it for 30 minutes, what would happen? Would it fill the disc with the 30 minutes? Is that possible?
very interesting your topic is....
have no problems using rams or -r's
in the 50 though, use f-rec all the time
tried for 45 minutes though, and it
still left 15 empty using f-rec, on xp mode
i had had it set on...i hope this helps
Panasonic DMR e60 ep no progressive out
By mammo1789 in forum Newbie / General discussionsReplies: 1Last Post: 2nd May 2012, 17:58 -
Question about SD card for Panasonic HMC150
By jeanpave in forum EditingReplies: 11Last Post: 11th Jun 2011, 22:11 -
Panasonic Firmware question
By vetski179 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2009, 19:30 -
Panasonic AY-DVM83MQ vs. Panasonic AY-DVM83PQ and AY-DVM80XJ question.
By Cyrax9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Feb 2008, 12:37 -
Question on new Panasonic dvd recorders
By heman28 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 20th Feb 2008, 11:37
