I have a LG GSA-4040B and I downloaded the new A302 firmware but everytiem I try to open the file it says "Windows cannot access the specified device, path, or file. You may not have the appropriate permissions to access the item." What can I do about this?
I am not sure if this will work but it has worked for me in the past. Go into run => regedit and goto:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
and set Allocatecdroms to (1)
if that doesn't word try this:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SeCEdit\Reg Values
and set the value to (0)
It's worth a shot. You may also look at permissions at these various levels to see if they allow you to access the CDROMS. Good luck! -
kustomkla80,
That simply a Windows permission problem. Just go in to your registry and set EVERYTHING up as allowed. That will prevent that problem in the future.
GE DV1 No Firmware Update What Is Up??
By DJboutit in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2011, 23:16 -
WD TV Live: New 1.01.17 firmware update available
By MJA in forum Media Center PC / MediaCentersReplies: 31Last Post: 30th Jan 2010, 21:42 -
Where to Get Firmware Update
By Teac23 in forum ComputerReplies: 1Last Post: 26th Apr 2009, 14:52 -
DVP642 - Did they ever update the Firmware?
By kelemvor in forum DVD & Blu-ray PlayersReplies: 3Last Post: 21st May 2008, 09:50 -
update firmware
By avextraxjp in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2008, 23:46
