Until now I was working with avi files that had ac3 soundtracks and I pretty much mastered the way to deal with them using Vdub---Ac3fix-----and finally TDA to combine it with the .m2v file.
Now How do I go about non ac3 files, as I was reading that audio encoding in Tmpgenc is not recommended and TDA will only accept ac3 or PCM audio formats for dvd burning.
Do I need to extract sound from avi files and then save it in .wav format? How do I convert to PCM?
What is the best way to deal with these files to burn them on a Dvd.
TDA will accept AC3, WAV and MP2 audio so you have a few choices.
You can use VirtualDub to extact the audio from the AVI file as a WAV file, then use a tool such as ffmpeg to convert the wav file to either MP2 or AC3. -
In virtualdub goto audio>full processing mode. goto conversion settings make sure its 48000 hz stereo 16 bit, if not enabler the ocnversion.
Click file>save wav.
Then encode using besweet or headac3he -
Originally Posted by duhmez
Can a file with regular soundtrack be converted to AC3? If so I can use ac3fix to run the audio extracted by vdub through it. -
I extract the audio (of course many apps will do this - VDub is good) and my audio is already 48000 hz, but I know there are numerous programs to resample, if needed and there is a "donate ware" plugin for Nero at http://neroplugins.cd-rw.org/ , if you have Nero. You can then use Nero's Wave Editor to convert to AC3. I have been using this method for the past couple of weeks, and thus far, all seems fine.
Originally Posted by Baldrick
Thanks Man. The process you suggested is very simple, I will try this first and see if it works on my DVD player.
Thanks all.
MKV files with Audio in DTS need to convert audio to AC3
By THEHNIC in forum AudioReplies: 5Last Post: 3rd Jun 2011, 08:17 -
AC3 .avi files trouble playing the sound in WINAMP
By NEVERMORE in forum AudioReplies: 0Last Post: 13th Sep 2010, 22:27 -
mencoder, convert mkv to avi + ac3. sound issues
By clavain in forum Video ConversionReplies: 1Last Post: 29th Jan 2008, 17:02 -
Trying to Convert avi. (Dvix) with AC3 audio file to DVD Format
By carlos305 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2007, 08:54 -
Extract sound from AVI video and convert to AC3
By blizzery in forum AudioReplies: 2Last Post: 25th Jul 2007, 14:06
