is ther away to do this, coz when i try to use tmpgenc for it, it says its an illegal mpeg stream
Well, to demux an AVI in TMPGEnc, you use the main program screen, which can take awhile.
A better solution is Virtual Dub mod. Load your video, select File-->Save Wav...
Then go to TMPGEnc MPEG Tools and demux the video from the original video.Hello. -
ummm. what is it your exactly trying to do? if you want to strip out the audio use virtualdub to save audio as wav file.
im trying to join two avi's but vdub says that the audio does not match, and will not join them for me, so the plan was to separate the video and audio in both files then join the video, the re-sample the audio then join that then re-mux
Just use Virtualdub. Under Video select direct stream copy and under Audio select No Audio. Do this seperately to each of your AVI's. Then try merging them by opening up the first AVI and select Append To AVI. You'll have to use another program to merge your two wav files though.
Conversion or demultiplexing of TRP files
By ranmamez in forum DVB / IPTVReplies: 2Last Post: 26th Oct 2011, 09:50 -
out of sync when demultiplexing
By calanda in forum Authoring (DVD)Replies: 5Last Post: 5th Aug 2010, 02:04 -
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10
