hi
i have done quite a few dvd to vcd but just latley im having a prob when im converting i get horizontal lines on the files and it slowley gets worse i cannot think of whats wrong as i never had this prob before its not just one film i tried a few
any ideas would be appreciated
thanks
We all started somewhere don't be affraid to ask
It be cause it is a interlaced dvd ... i think that is it.. depending on the program u to rip them and change them depends on the name of the setting.. im not exacly sure what ur using. The setting is it called the diinterlace field. There is about 4 diferant types to use to just expeiment ripping a few minutes on each. I have noticed that this only occurs when there is sideways movement.
HOpe this helps
ICU2
Dark Horizontal Lines
By daave in forum Capturing and VCRReplies: 4Last Post: 14th Aug 2012, 15:26 -
Horizontal distortion lines
By hyku1147 in forum Newbie / General discussionsReplies: 5Last Post: 27th Nov 2011, 10:02 -
horizontal lines in mpeg2
By thecrock in forum Newbie / General discussionsReplies: 6Last Post: 15th Dec 2008, 17:05 -
Horizontal Lines - Converting
By jooleyen in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2008, 19:59 -
Help - Horizontal Lines
By Hiram_Abif in forum Newbie / General discussionsReplies: 8Last Post: 9th Aug 2007, 12:06
