i dont know how to post pictures on forums can anyone help me out??is it the same for all forums??? im a newbie to forums
Easy:
1. Select the picture and make sure it is jpg,gif, or png format. Also make sure it is about 50 kB, although the forum does not seem to be particular about the size.
2. Go to the Post a reply section, select the Browse button, and select your picture. The box next to the browse button should now contain the entire path to your picture on your computer.
3. When you return to the Post a reply section, in the message body, type only the file name of your picture (e.g., tommy.jpg). Do not include the entire path here! Highlight the file name and select the "Img" button above. The filename will now have the phrases:
"[ img ]" and "[ /img ]"
bracketing the file name, (minus the spaces). You can now select submit, and if the file is the right size and format, you will be returned to Forum section, and your image will appear.
Now, go to the Test forum and practice there.Hello. -
wrote by tommy knocker"Also make sure it is about 50 kB"
so u cant post any thing above 50 kb, is this all forums?
Want to post pictures for online viewing
By coody in forum Video Streaming DownloadingReplies: 7Last Post: 25th Feb 2009, 13:03 -
New Forums
By stiltman in forum Off topicReplies: 0Last Post: 26th Feb 2008, 11:49 -
all forums or
By ban_jhon in forum Off topicReplies: 2Last Post: 11th Dec 2007, 02:28 -
Forums etiquette
By Lucifers_Ghost in forum Off topicReplies: 21Last Post: 2nd Aug 2007, 05:04 -
AMD forums
By gmcman in forum Off topicReplies: 1Last Post: 9th May 2007, 22:27
