ok so i bought my new DVD-R a few days ago, everything so far seems to be going great.
but now i want to put my divx(avi format films) onto dvd, i know i need to convert it to MPEG2 to then author it into VOB files etc.
but what is the fastest encoder out there (iam using tmpgenc) its taking 7hrs (no idea why my machine is brand new has the best specs etc)
maybe iam doing something wrong but how can i cut this down to 3-4 hrs
I have heard CCE is pretty fast, but the full version is quite pricey. The stripped down version is faster than TMPGEnc , but does not have as many functions.
So, the best bet, in my opinion, is to use the TMPGEnc Preview function to check for settings integrity, and recording short sample videos to ensure quality. Then encode the full video when it meets your standards.Hello. -
What settings are you using for Tmpgenc? it does take time to convert using Tmpgenc , but quality takes time.
i author dvd using Tmpgenc DVD author. simple to use. others will recommend using it or dvd-lab. lots of choices, several have free trial for you to test it out. -
it may actually have something to do with me doing the sound in tmgpenc as well.
i dont fully understand how to do it seperately
does anyone have a guide ? (preferably a simple one) -
ok iam doing the audio separtely with virtuadub, and so far it seems everything is going alot quicker on tmgpenc (total time is 3 hrs instead of 8) so its going ok ,
*(TOUCHES WOOD)* -
We also drive on the right side of the road, and say fries instead of chips!Originally Posted by Tommyknocker
Newbie bluetooth questions
By videohalp in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2011, 05:37 -
newbie x264fw questions
By anthell in forum Newbie / General discussionsReplies: 3Last Post: 10th May 2010, 05:33 -
Newbie Software Questions
By AAOBill in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2010, 00:42 -
Some newbie questions about sirius
By janeydoll in forum AudioReplies: 9Last Post: 10th Jun 2008, 02:19 -
Newbie Mplayer questions
By Maikeru-sama in forum Video ConversionReplies: 2Last Post: 21st Dec 2007, 14:51
