If they are for VCD, 23.976 will be fine. If they are svcd you must now run pulldown on them.
I think you mean this: The source is 23.97 Film, and you encoded to 29.97 NTSC? That's not a problem. You have a little wasted bitrate encoding the extra false fields, but it's no big deal. If the final product looks good then leave it (it tends to have less flicker in my eye than 23.97 with 3:2 poulldown set).
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I think you'll notice an ugly stuttering effect when you watch the VCD, especially on smooth slow pans. Other than that all you have is a reduction in bitrate available for encoding other data which could manifest itself in your video in action scenes.
If you have the time, re-encode them. You'll not only remove that stuttering effect, but your video will look better too since there will be a 20% improvement in bitrate. High action scenes will have little to no blocking artifacts.
Darryl -
Actually, some better advice as stated in many other posts on this board would be to encode everything 23.976 and leave it. Most new DVD players will automatically play it back at 29.97fps if necessary. I found out the quality is not only better but 3:2 pulldown ruins the smoothness. Whether you're making a VCD or a SVCD keep it at 23.976. You can burn it and ignore any compliance warning to see if your standalone will play it..I use a cd-rw disc for testing purposes. If you would rather take everyone else's advice and do a pulldown then do not use pulldown.exe...it sucks....and don't use the GUI that goes to it because that just runs pulldown.exe for you. Use this one instead, it's called DoPulldown 1.0 http://www.woofsoft.com/Downloads/Downloads_GetFile.aspx?id=53
I used it and the results are better than the 'popular' one but it still sucks compared to leaving it alone. Supposedly pulldown only flags the file to signal a playback at 29.97 but it does a helluva lot more than that to the file. I am not an expert but this is my experience. Good luck.
Using NTSC (16:9) and PAL (4:3) sources to restore a film...
By takearushfan in forum RestorationReplies: 61Last Post: 3rd Mar 2012, 16:13 -
NTSC/PAL but exact film length: How so?
By Anonymous5394 in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2010, 12:42 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 16:17 -
Question regarding NTSC Film DVD
By txporter in forum Video ConversionReplies: 14Last Post: 30th Nov 2009, 10:29 -
FPS NTSC & PAL Film/Digital
By flamingo in forum Newbie / General discussionsReplies: 5Last Post: 13th Nov 2007, 14:21
