Linked into another problem I'm having with reading a DVD on a Toshiba SD330E
I cannot read disc in windows although nero identifies the DVD as UDF(Mode 1) format with 1 track of data. I have tried installing a UDF reader but it made no difference.
Strangely the DVD can be read by my friends 'Time' machime DVD rewriter and also his standalone DVD player.
DVD writer is a Freecom badged NEC1300A with freecom v1.31 firmware.
Standalone is Toshiba SD330E and as mentioned in previous thread disc plays but is black and white and you get two images at top of screen with blank lower half.
Have I just bought the worst combination of drives?
I read forums on here and thought the Toshiba was going to be my best option.
HELP![]()
I'm pulling my hair out. and as the disc I'm trying is a copy I cant exactly run to the manufacturer. Disc is a R1 while player is multi region, Freccom unit is Region 2.
Running windows 98 isn't helping you (no native support).
I assume you are trying to copy a movie? You mention region 1 and region 2. If you DVD drive is the wrong region, generally speaking, it won't read the disk. It's a hardware/firmware issue.
Can DVDDecryptor access the disk or not? You may need to region patch your machine to get access to the disk(this can be done in software).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thanks for the reply. I have now managed to get to see the files on the DVD, I downloaded the latest version of Nero's UDF reader. I am now copying files off the disc and will use DVD video option to burn to a new DVD disc. I believe the difference is that Nero will now burn it in ISO format, hopefully that will then allow it to work with my Toshiba SD330.
I am using Windows XP, not 98.
My PC DVD (Freecom NEC1300A) is Region 2 and has a limited number of allowed changes so I do not want to touch that.
My standalone Toshiba SD330E is multi-region - although I have never actually tried a proper R1 disc as yet, only had the Toshiba 1 week.
Thanks for the help
Windows 7 Stuck in "read only" mode for USB THumbs and SD Cards etc..
By nerys in forum ComputerReplies: 26Last Post: 1st Mar 2012, 03:03 -
Random Read Only mode on my TM900
By Arch3type in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 21st Dec 2011, 00:29 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 13:21 -
JVC HR 9600....edit mode vs auto mode for digitizing s vhs or vhs
By fuzzblaster in forum Capturing and VCRReplies: 21Last Post: 21st Jan 2011, 09:28 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 16:27
