  1. Hi,
    I have made my wedding photo album DVD (1.5 GBytes) with MemoriesOnTV and my wedding video DVD (2.5 GBytes) with Pinnacle Studio 8. Both of the programs generated own menus for the DVDs. The disks are perfect for me, only problem I do not want to have them on two DVD disks.
    I am looking for a program which is able to combine the two disks to one DVD keeping both of the original menus and generate a main menu above them.
    Is that possible somehow?
    Thanks for the help in advance.
  2. Member wulf109's Avatar
    Jul 2002
    NO
  3. Member stackner's Avatar
    Feb 2004
    Digital World, Australia
    actually YES using dvdremake
  4. I have made my wedding photo album DVD (1.5 GBytes) with MemoriesOnTV and my wedding video DVD (2.5 GBytes) with Pinnacle Studio 8.
    Either remake your videos with one of those two programs or your could do this. Make both your slideshows with Slide Show Movie Maker. Then, import the avis into The Film Machine, convert them to mpeg 2. Then import them into GUI for DVD Author, and make your dvd. Take the output VIDEO_TS and AUDIO_TS folders from GUI for DVD Author and drag them onto a dvd and burn.
  5. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    as stackner mentions it is possible to join 2 DVD's keeping original menus but it's the PRO version that only allows this . My guides are in my signature for joining 2 DVD's
    it would probably be real simple to join the two if you created the DVD's yourself
